Hi there,
I have a few issue and hope one of you guys could guide me. I have setup a lab and to start with I have setup a basic MAC Auth service along with web auth for captive portal redirect.
1. In access tracker, I do not see Machine Authenticated role for the request even after logg off-log on and restart pc. This is a domain PC. I only see user authenticated role. What could be the issue here? I have attached the input from auth request.
2. The web portal redirect is not working. The mac auth sends a profile to redirect to captive portal but it doesnt happen. When I do the manual web auth, it hits the web auth service but again when web auth sends a radius COA, it doesnt hit back to MAC auth to get the guest profile and gets stuck in mac auth. In login page, I have tried both Cisco and captive portal with clearpass in vendor settings, both with same result.
I am not sure if my ACL is wrong or it has something to do with my Cisco switch running 15.2. attached is switch configuration and access tracker outputs.
