  • 1.  NPS 2008 - user auth and fails not showing in eventviewer?
    Posted Sep 08, 2011 06:55 AM
    Anybody have an idea what might be causing NPS 2008 to not show authentication events in eventviewer?
    I've filtered on source "Microsoft Windows security auditing" and "NPS" but nothing shows up. I did also set a filter for event ID 6273, 1 and 2 as otherwise the eventviewer is spammed by non-radius events.
    Even without the filters I cannot find the user authentication events anywhere.. so anybody got an idea?
  • 2.  RE: NPS 2008 - user auth and fails not showing in eventviewer?
    Posted Sep 08, 2011 07:04 AM
    Go under Custom Views> Server Roles> Network Policy and Access Services.
  • 3.  RE: NPS 2008 - user auth and fails not showing in eventviewer?
    Posted Nov 29, 2011 11:11 AM
    Ran into this with another customer today. Dug in a bit and found what I needed:
    auditpol /set /subcategory:"Network Policy Server" /success:enable /failure:enable
    source: http://support.microsoft.com/kb/951005
    SYMPTOMS
    In Windows Server 2008, the Network Policy Server (NPS) may not log successful authentication events or failed authentication events in the Security log in Event Viewer. This behavior occurs even though Event Viewer is configured correctly to log such events.
    This problem may occur on a fresh installation of Window Server 2008.
    RESOLUTION
    To resolve this issue, follow these steps:
    1. Click Start, type cmd in the Start Search box, right-click cmd in the Programs list, and then click Run as administrator.
      If you are prompted for an administrator password or for confirmation, type the password, or click Continue.
    2. At the command prompt, type the following command, and then press ENTER:
