Wired Intelligent Edge
  • 1.  NTP Sync issue on 5402zl2 & 2930F
    Posted Oct 03, 2018 07:59 AM
    We recently replaced a Customer's Cisco environment with Aruba 5402 zl2 as Core & 2930F as distribution switches. Everything was smooth until we discovered NTP was not getting synced on any of the switches.
    Scenario tested:
    -Switches were put same VLAN as NTP server.
    - ip dns domain-name command was used.
    - Firmware WC.16.06 upgraded.
    -Aruba TAC was aligned
    Followings are commands
    timesync ntp
    ntp unicast
    ntp server 172.16.1.12 iburst
    ntp server 172.16.12.11 iburst
    ntp enable
    time timezone 530 (IST)
    When we run NTP status - we see not syncronized.
    Can anyone suggest what further troubleshooting can be done?
    Thank you!
  • 2.  RE: NTP Sync issue on 5402zl2 & 2930F
    Posted Oct 04, 2018 04:25 AM
    So I guess you already checked layer 3 reachability (firewalls, routing etc) to the NTP-server?
    Are you able to try SNTP?
    timesync sntp
    sntp unicast
    sntp server priority 1 <ip>
  • 3.  RE: NTP Sync issue on 5402zl2 & 2930F
    Posted Oct 04, 2018 06:33 PM
    Greetings!
    Here is another command (with example output) that you can use for NTP troubleshooting:
    switch(config)# show ntp associations detail
     NTP Association Information
      IP Address     : xx.xx.xx.xx          Peer Mode         : Server
      Status         : Config,Sane,Master   Peer Poll Intvl   : 10
      Stratum        : 3                    Root Delay        : 0.05072 sec
      Ref Assoc ID   : 1                    Root Dispersion   : 0.04526 sec
      Assoc Name     : NTP Association 1    Reach             : 177
      Reference ID   : xx.xx.xx.xx          Delay             : 0.00000 sec
      Our Mode       : Client               Offset            : 0.00000 sec
      Our Poll Intvl : 10                   Precision         : 2**-23
      Dispersion     : 12.83116 sec
      Association In Packets      : 45
      Association Out Packets     : 45
      Association Error Packets   : 1
      Origin Time     : Thu Oct  4 15:14:35 2018
      Receive Time    : Thu Oct  4 15:14:35 2018
      Transmit Time   : Thu Oct  4 15:14:35 2018
      Filter Delay =  0.0009 0.0008 0.0010 0.0010 0.0009 0.0009 0.0000 0.0000
      Filter Offset = 0.1020 0.0796 0.0715 0.0589 0.0431 0.0082 0.0000 0.0000
      IP Address     : xx.xx.xx.xx          Peer Mode         : None
      Status         : Config,Insane        Peer Poll Intvl   : 17
      Stratum        : 16                   Root Delay        : 0.00000 sec
      Ref Assoc ID   : 2                    Root Dispersion   : 0.00000 sec
      Assoc Name     : NTP Association 2    Reach             : 0
      Our Poll Intvl : 10                   Precision         : 2**0
      Dispersion     : 16.00000 sec
      Association In Packets      : 0
      Association Out Packets     : 168
      Association Error Packets   : 0
      Origin Time     : Mon Jan  1 00:00:00 1990
      Receive Time    : Mon Jan  1 00:00:00 1990
      Transmit Time   : Thu Oct  4 15:21:21 2018
      Filter Delay =  0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
      Filter Offset = 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
    Also, check the switch event logs for reachability errors or any other reported issues.
  • 4.  RE: NTP Sync issue on 5402zl2 & 2930F
    Posted Oct 11, 2018 03:24 AM
    We used Wireshark in next level of troubleshoots. NTP Sync packets were sent to windows servers. We then tried to SNTP with following commands:
    timesync sntp
    sntp unicast
    sntp 30 (30 sec poll intervals)
    sntp server priority 1 172.16.1.12
    time timezone 330 (for IST)
    Authentication is not used. we just migrated to SNTP protocol and it worked!
    To conclude further I guess Aruba have compatibilty issues between NTP protocol & Windows NTP server.
    Thanks!
