yes it is 256.
You can check it using Feature navigator also remember to enable the "scale numbers"
Original Message:
Sent: Sep 22, 2023 07:57 AM
Subject: Number of VRFs supported on 8325
Hi
There was once a number of 256 VRFs mentioned ... at least with Version 10.06. Unfortunately, there is no info about it in the datasheet as well as not in the "show capacities" output.
So, I would plan with 256.
Best,
Thomas
Original Message:
Sent: 9/22/2023 6:45:00 AM
like subject said, I like to know is there any limitation ?
BR,
Mladen
