OAW-4550
  • 1.  OAW-4550
    Posted Feb 05, 2017 11:25 AM
    Hi Experts,
    Please i need your help yesterday i was able to ping the IP of the controller by connecting to interface of port 2 with my laptop
    suddenly it is stopped pinging i was unable to ping the controller ip what could be the issue?
    (OAW-4550) #show ip interface brief
    Interface                   IP Address / IP Netmask        Admin   Protocol
    vlan 10                  10.200.200.11 / 255.255.248.0     up      up
    vlan 1                  192.168.10.100 / 255.0.0.0         up      up
    loopback                   unassigned / unassigned        up      up
    (OAW-4550) #
    (OAW-4550) #
    (OAW-4550) #
    (OAW-4550) #show vlan
    VLAN CONFIGURATION
    VLAN  Description  Ports                       AAA Profile
    1     Default      GE0/0/3 GE0/0/4-0/5 Pc0-7   N/A
    10    VLAN0010     GE0/0/3 GE0/0/4-0/5         N/A
    (OAW-4550) #show port stat?
    stats                   Show physical port statistics
    status                  Show physical port status
    Port Status
    Slot-Port  PortType  adminstate  operstate  poe  Trusted  SpanningTree  PortMode
    0/0/0      GE        Enabled     Down       N/A  Yes      Disabled      Trunk
    0/0/1      GE        Enabled     Up         N/A  Yes      Disabled      Trunk
    0/0/2      GE        Enabled     Up         N/A  Yes      Disabled      Access
    0/0/3      GE        Enabled     Up         N/A  Yes      Forwarding    Trunk
    0/0/4      GE        Enabled     Down       N/A  Yes      Disabled      Trunk
    0/0/5      GE        Enabled     Down       N/A  Yes      Disabled      Trunk
    (OAW-4550) #ping 10.200.200.11
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 10.200.200.11, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 0.043/0.0564/0.091 ms
    (OAW-4550) #
     The problem i was not able to ping the ip by lan cable it was pinging from console?
    Next thing and i need to connect the alcatel core switch +controller+edgeswitch
    where all the aps getting ip addresses from the controller dhcp
    what configuartion to be done in all the 3 switches.? whtether trunk port in all switches or what?
    please very grateful if somebody help me
  • 2.  RE: OAW-4550
    Posted Feb 05, 2017 06:48 PM
    Since you are connecting your laptop directly to the switch port, it should be configured as "access"  in the VLAN you want your laptop to be in! Once done, it should be fine.
  • 3.  RE: OAW-4550
    Posted Feb 05, 2017 11:38 PM
    Can you tell me i was not able to reach the edge switch from the controller and all the Access points are down
    configuration in the controller with vlan 10 ip add 10.200.200.11
    core switch with vlan 10 ip add 10.200.200.1
    edge switch with vlan 50 ip add 10.200.200.8 and all are in same subnet
    controller+coreswitch+edgeswitch
    there is a one fiber uplink from controller(0/0/2) to core switch(1/1/13)and also one uplink to edge switch(1/49) from the core switch.
    Please help me to reslove the issue its a hotel i want to make all the AP up today IP to the access points are given by controller
    Help required.
  • 4.  RE: OAW-4550
    Posted Feb 06, 2017 05:59 PM
    Please share your configs for :
    - controller(0/0/2)
    - core switch(1/1/13)
    - edge switch(1/49) & Core Switch port config on other side
  • 5.  RE: OAW-4550
    Posted Feb 07, 2017 08:03 AM
    Controller:
    VLAN CONFIGURATION
    1 VLAN0001 GE0/0/0-0/4 GE0/0/5 Pc0-7 Hotel-Holiday-inn-aaa_prof
    vlan 1                   10.200.200.11 / 255.255.248.0     up      up
    Core switch:
    > show vlan members port members
    vlan port type status
    90 1/1/13 default forwarding ---------------------------------->>>>>>> fiber up-link from controller to core switch
    -> show vlan
    vlan type admin oper ip mtu name
    1 std Ena Ena Dis 1500 VLAN 1
    10 std Ena Dis Dis 1500 VLAN 10
    90 std Ena Ena Ena 1500 VLAN 90
    4094 vcm Ena Ena Dis 1500 VCM IPC
    -> show ip interface b
    Total 7 interfaces
    Flags (D=Directly-bound)
    Name IP Address Subnet Mask Status Forward Device Flags
    EMP-CHAS1 192.168.10.1 255.0.0.0 DOWN NO EMP
    EMP-CMMA-CHAS1 0.0.0.0 0.0.0.0 DOWN NO EMP
    EMP-CMMA-CHAS2 0.0.0.0 0.0.0.0 DOWN NO EMP
    Loopback 127.0.0.1 255.255.255.255 UP NO Loopback
    dhcp-client 0.0.0.0 0.0.0.0 DOWN NO unbound
    int-50 0.0.0.0 0.0.0.0 DOWN NO unbound
    vlan-90 10.200.200.1 255.255.248.0 UP YES vlan 90
    Edge switch :
    Welcome to the Alcatel-Lucent OmniSwitch 6450
    Software Version 6.6.5.63.R02 GA, December 16, 2014.
    Copyright(c), 1994-2014 Alcatel-Lucent. All Rights reserved.
    OmniSwitch(TM) is a trademark of Alcatel-Lucent registered
    in the United States Patent and Trademark Office.
    -> show vlan port
    1 1/50 default inactive
    1 2/49 default inactive
    1 2/50 default inactive
    1 3/50 default inactive
    1 4/3 default inactive
    1 4/4 default inactive
    1 4/5 default inactive
    1 4/6 default inactive
    1 4/7 default inactive
    1 4/8 default inactive
    1 4/9 default inactive
    1 4/10 default inactive
    1 4/11 default inactive
    1 4/12 default inactive
    1 4/13 default inactive
    1 4/14 default inactive
    1 4/15 default inactive
    1 4/16 default inactive
    1 4/17 default inactive
    1 4/18 default inactive
    1 4/19 default inactive
    1 4/20 default inactive
    1 4/21 default inactive
    1 4/22 default inactive
    1 4/23 default inactive
    1 4/24 default inactive
    1 4/25 default inactive
    1 4/26 default inactive
    1 5/3 default inactive
    1 5/4 default inactive
    1 5/9 default inactive
    1 5/10 default inactive
    1 5/11 default inactive
    1 5/12 default inactive
    1 5/13 default inactive
    1 5/14 default inactive
    1 5/15 default inactive
    1 5/16 default inactive
    1 5/17 default inactive
    1 5/18 default inactive
    1 5/19 default inactive
    1 5/20 default inactive
    1 5/21 default inactive
    1 5/22 default inactive
    1 5/23 default inactive
    1 5/24 default inactive
    1 5/25 default inactive
    1 5/26 default inactive
    112 1/1 default forwarding
    112 1/2 default inactive
    112 1/3 default forwarding
    112 1/4 default inactive
    112 1/5 default forwarding
    112 1/6 default inactive
    112 1/7 default forwarding
    112 1/8 default inactive
    112 1/9 default forwarding
    112 1/10 default inactive
    112 1/11 default forwarding
    112 1/12 default inactive
    112 1/13 default forwarding
    112 1/14 default inactive
    112 1/15 default forwarding
    112 1/16 default inactive
    112 1/17 default forwarding
    112 1/18 default inactive
    112 1/19 default forwarding
    112 1/20 default inactive
    112 1/21 default forwarding
    112 1/22 default inactive
    112 1/23 default forwarding
    112 1/24 default inactive
    112 1/25 default forwarding
    112 1/26 default forwarding
    112 1/27 default forwarding
    112 1/28 default inactive
    112 1/29 default forwarding
    112 1/30 default inactive
    112 1/31 default forwarding
    112 1/32 default inactive
    112 1/33 default forwarding
    112 1/34 default inactive
    112 1/35 default forwarding
    112 1/36 default inactive
    112 1/37 default forwarding
    112 1/38 default inactive
    112 1/39 default forwarding
    112 1/40 default inactive
    112 1/41 default forwarding
    112 1/42 default forwarding
    112 1/43 default inactive
    112 1/44 default forwarding
    112 1/45 default forwarding
    112 1/46 default inactive
    112 1/47 default forwarding
    112 1/48 default inactive
    112 1/49 default forwarding
    112 4/1 default forwarding
    112 4/2 default forwarding
    1112 3/1 default inactive
    1112 3/2 default inactive
    1112 3/3 default inactive
    1112 3/4 default inactive
    1112 3/5 default inactive
    1112 3/6 default inactive
    1112 3/7 default inactive
    1112 3/8 default inactive
    1112 3/9 default inactive
    1112 3/10 default inactive
    1112 3/11 default inactive
    1112 3/12 default inactive
    1112 3/13 default inactive
    1112 3/14 default inactive
    1112 3/15 default inactive
    1112 3/16 default inactive
    1112 3/17 default inactive
    1112 3/18 default inactive
    1112 3/19 default inactive
    1112 3/20 default inactive
    1112 3/21 default inactive
    1112 3/22 default inactive
    1112 3/23 default inactive
    1112 3/24 default inactive
    1112 3/25 default inactive
    1112 3/26 default inactive
    1112 3/27 default inactive
    1112 3/28 default inactive
    1112 3/29 default inactive
    1112 3/30 default inactive
    1112 3/31 default inactive
    1112 3/32 default inactive
    1112 3/33 default inactive
    1112 3/34 default inactive
    1112 3/35 default inactive
    1112 3/36 default inactive
    1112 3/37 default inactive
    1112 3/38 default inactive
    1112 3/39 default inactive
    1112 3/40 default inactive
    1112 3/41 default inactive
    1112 3/42 default inactive
    1112 3/43 default inactive
    1112 3/44 default inactive
    1112 3/45 default inactive
    1112 3/46 default inactive
    1112 3/47 default inactive
    1112 3/48 default inactive
    1112 3/49 default inactive
    1112 5/5 default inactive
    1112 5/6 default inactive
    1112 5/7 default inactive
    1112 5/8 default inactive
    2047 2/48 default inactive
    2201 2/1 default inactive
    2202 2/2 default inactive
    2203 2/3 default inactive
    2204 2/4 default inactive
    2205 2/5 default inactive
    2206 2/6 default inactive
    2207 2/7 default inactive
    2208 2/8 default inactive
    2209 2/9 default inactive
    2210 2/10 default inactive
    2211 2/11 default inactive
    2212 2/12 default inactive
    2213 2/13 default inactive
    2214 2/14 default inactive
    2215 2/15 default inactive
    2216 2/16 default inactive
    2217 2/17 default inactive
    2218 2/18 default inactive
    2219 2/19 default inactive
    2220 2/20 default inactive
    2221 2/21 default inactive
    2222 2/22 default inactive
    2223 2/23 default inactive
    2224 2/24 default inactive
    2225 2/25 default inactive
    2226 2/26 default inactive
    2227 2/27 default inactive
    2228 2/28 default inactive
    2229 2/29 default inactive
    2230 2/30 default inactive
    2231 2/31 default inactive
    2232 2/32 default inactive
    2233 2/33 default inactive
    2234 2/34 default inactive
    2235 2/35 default inactive
    2236 2/36 default inactive
    2237 2/37 default inactive
    2238 2/38 default inactive
    2239 2/39 default inactive
    2240 2/40 default inactive
    2241 2/41 default inactive
    2242 2/42 default inactive
    2243 2/43 default inactive
    2244 2/44 default inactive
    2245 2/45 default inactive
    2246 2/46 default inactive
    2247 2/47 default inactive
    2248 5/1 default inactive
    2249 5/2 default inactive
    -> show vlan
    stree mble src
    vlan type admin oper 1x1 flat auth ip tag lrn name
    1 std on off on on off off off on wireless
    112 std on on on on off off off on AP-2NDFLR
    1112 std on off on on off off off on IPTV-2NDFLOOR
    2047 std on off on on off off off on R-2047 ------- vlan for data ports
    2201 std on off on on off off off on R-201
    2202 std on off on on off off off on R-202
    2203 std on off on on off off off on R-203
    2204 std on off on on off off off on R-204
    2205 std on off on on off off off on R-205
    2206 std on off on on off off off on R-206
    2207 std on off on on off off off on R-207
    2208 std on off on on off off off on R-208
    2209 std on off on on off off off on R-209
    2210 std on off on on off off off on R-210
    2211 std on off on on off off off on R-211
    2212 std on off on on off off off on R-212
    2213 std on off on on off off off on R-213
    2214 std on off on on off off off on R-214
    2215 std on off on on off off off on R-215
    2216 std on off on on off off off on R-216
    2217 std on off on on off off off on R-217
    2218 std on off on on off off off on R-218
    2219 std on off on on off off off on R-219
    2220 std on off on on off off off on R-220
    2221 std on off on on off off off on R-221
    2222 std on off on on off off off on R-222
    2223 std on off on on off off off on R-223
    2224 std on off on on off off off on R-224
    2225 std on off on on off off off on R-225
    2226 std on off on on off off off on R-226
    2227 std on off on on off off off on R-227
    2228 std on off on on off off off on R-228
    2229 std on off on on off off off on R-229
    2230 std on off on on off off off on R-230
    2231 std on off on on off off off on R-231
    2232 std on off on on off off off on R-232
    2233 std on off on on off off off on R-233
    2234 std on off on on off off off on R-234
    2235 std on off on on off off off on R-235
    2236 std on off on on off off off on R-236
    2237 std on off on on off off off on R-237
    2238 std on off on on off off off on R-238
    2239 std on off on on off off off on R-239
    2240 std on off on on off off off on R-240
    2241 std on off on on off off off on R-241
    2242 std on off on on off off off on R-242
    2243 std on off on on off off off on R-243
    2244 std on off on on off off off on R-244
    2245 std on off on on off off off on R-245
    2246 std on off on on off off off on R-246
    2247 std on off on on off off off on R-247
    2248 std on off on on off off off on R-248
    2249 std on off on on off off off on R-249 -------vlan for data ports
    Total 2 interfaces
    1 0.0.0.0 0.0.0.0 DOWN NO unbound
    Loopback 127.0.0.1 255.0.0.0 UP NO Loopback
    Thanks for your support
  • 6.  RE: OAW-4550
    Posted Feb 19, 2017 11:59 AM
    Hi ,
    I need to know that in my scenario im having one wlan controller 4550 and there is one uplink from controller to core switch alcatel and one uplink to edge switch from core switch there are 6 floors means six uplinks are going to each floor for one poe edge switch
    the client requirement is they need all access points to be separated floor wise say eg 2nd floor vlan 112,3rd floor vlan 113 etc.. And management vlan
    But right now I configured for 2nd floor I can able to reach my controler to 2nd floor edge switch and core switch through console .
    Also I need to check with my laptop by assigning dhcp in laptop so that It have to get ip from controller so that i can tell them our configuration is perfect.
    So how can I configure the all vlan in controller to reach with core switch and edge switch
    Please somebody can guide me
    If you need configuration I will share
  • 7.  RE: OAW-4550
    Posted Feb 19, 2017 06:13 PM
    Are you using dedicated management interface on the controller? If not, the uplink on your controller will be a trunk that will carry multiple VLANs.
    For Access Points perspective, you only need L3 reachability between your controller and Access Points.Your floor VLANs are not required to be present on your controller.
    Just make sure you access points are able to discover the controller. Through DHCP, DNS or statically, whatever you have configured in your network.
  • 8.  RE: OAW-4550
    Posted Feb 19, 2017 11:26 PM
    Can you tell me where to add vlans in the controller port 0/0/3 ?? so it will take automatically by Access points through PoE switch
    see the attached pic for your reference
    I made trunk port but not sucessful only i can able to reach vlan 112(which is configured as controller uplink vlan) and not vlan 113
  • 9.  RE: OAW-4550
    Posted Feb 20, 2017 05:33 PM
    Aruba controller, by default, allows all VLANs on the trunk interface. You can verify this by "show trunk" command that will list the VLANs that are allowed to be passed over trunk link from Aruba controller.
    If you can see your VLANs listed in the show trunk output, you need to check stuff on your Alcatel switches.
    Also make sure native LVAN is matching on both sides.
  • 10.  RE: OAW-4550
    Posted Mar 05, 2017 06:27 AM
    Hi Jibran,
    Hope you doing good!
    Access points are not getting the dhcp lease from the controller but in the same port i can get the ip to my laptop from the contorller when i set to dhcp in laptop what could be the issue.
    Access points are getting ip from the contorller i can able to see from the console that it getting ip form the master
    But the ping response is not happening continuosly
    Laptop connected in switch port 6450 -1/24 also i attached logs for your reference.
    i try to ping the controller ip 10.0.3.5 from the console connected to APIN205 im getting ping 10 secs after that it is coming network unreachable then once agian i was trying to ping it is pinging this is the scenario
    What could be the issue then how my laptop getting dhcp ip range from the controller.??  Please explain
     Note: when i connect to wifi ssid in laptop it is taking auto configuration ip ???
    Attachment(s)
    txt
    core6900-log.txt   4 KB 1 version
  • 11.  RE: OAW-4550
    Posted Mar 05, 2017 05:36 PM
    I cannot see any issue with the Ping here. Is there any firewall between your Access Point and Controller? We need to make sure PAPI traffic is allowed between the controller and Access Point.
    Also, the DHCP scope is configured on the controller or Core switch? Have you added DHCP options 43/60 to send master controller IP Address?
  • 12.  RE: OAW-4550
    Posted Mar 06, 2017 08:54 AM
    Hi Jibran,
    Yes DHCP option is configured in controller
    Can you tell im getting the network unreachable to the controller
    from  the access point when i  try to reach the controller IP 10.0.3.5
    Also where is the option to enable 43/60 in the controller?
    What do you meant by PAPI traffic how to enable that as well
    Note: Attcahed screenshot of AP bootup
    Attachment(s)
    txt
    ap-working.txt   4 KB 1 version
  • 13.  RE: OAW-4550
    Posted Mar 06, 2017 07:32 PM
    Looks like you are getting the Master IP.
    AP and controller communicate via PAPI (UDP port 8211).
    PAPI is used for config download and control channels for ARM and Wireless Intrusion Detection System (WIDS) communication to the master controller. You have to make sure UDP Port 8211 is opened all the way from your Access Point to the Aruba Controller.
    Also, have you checked your routing? Your Controller (10.0.3.5) & Access Point (10.0.0.22) are on different subnet.
  • 14.  RE: OAW-4550
    Posted Mar 06, 2017 07:36 PM
    OK, I believe we have found the problem here. Default gateway is not assigned to your Access Point.
    10.0.0.22 255.255.254.0
    Running ADP...Done. Master is 10.0.3.5
    Check DHCP configuration on your controller.  From the config you shared earlier, I am sure you do not have any L3 interface in 10.0.0.x subnet. Your Controller is not acting as DHCP server for the Access Point!
  • 15.  RE: OAW-4550
    Posted Mar 07, 2017 04:26 AM
    Hi Jibran ,
    After changing the IP address of controller from 10.0.3.5 to 10.0.0.1 the problem got resolved.
    I connected my WINDOWS Phone to the wifi but it got IP first time after disconnecting the wifi from the phone later it is taking auto configuration IP  ?
  • 16.  RE: OAW-4550
    Posted Mar 13, 2017 01:35 AM
    HI Jibran,
    Access points in some specific floors are not getting IP from controller.
    But same configuartion in each floors
    2 ,3,4,& 5th floor are getting IP's from the controller
    But 6th floor AP's are not getting IP
    Here I have attached switch CONFG for the AP's installed in the 4thfloor(getting IP) and 6th floor(Not getting IP)
    Attachment(s)
    txt
    6th-floor-switch-conf.txt   9 KB 1 version
    txt
    4th-floor-switch-conf.txt   10 KB 1 version
