Comware
  • 1.  OID objects for HP A10504
    Posted Oct 01, 2012 09:15 AM
    We have HP A10504 and would like to gather SNMP statistic for this device.
    Could someone, please, advise me with OID for:
    1. PSU status.
    2. Serial number of chassis
    3. The Temperature of chassis.
    I spend a lot of time trying to find these ODIs, but with no luck.
    #snmp
  • 2.  RE: OID objects for HP A10504
    Posted Oct 02, 2012 10:15 AM
    Have you downloaded the MIB and checked it for the OIDs you need?
    https://h10145.www1.hp.com/downloads/DownloadSoftware.aspx?SoftwareReleaseUId=9683&ProductNumber=JC613A&lang=&cc=&prodSeriesId=&SerialNumber=&PurchaseDate=
    There are "quick reference" text files in there describing the different OIDs you can access and what they are for.
    Hope that helps you out.
