Wired Intelligent Edge
  • 1.  OID/MIB translation with Kiwi
    Posted May 10, 2019 01:04 PM
    We use Kiwi Syslog to monitor SNMP traps from our HP/Aruba switches (such as J9728A Aruba 2920 48G Switch).
    Kiwi translates the OIDs to readable text, but in this case Kiwi does not know how to translate all of them, and require MIBs from the vendor.
    I have found this page with MIB downloads:
    https://h10145.www1.hpe.com/Downloads/SoftwareReleases.aspx?ProductNumber=J9728A&lang=en&cc=us&prodSeriesId=3231819
    I have tried sending them a couple of different MIB packages, such as this one (J9728A Aruba 2920 48G Switch
    Software: MIBs-Nov-2018):
    https://h10145.www1.hpe.com/Downloads/DownloadSoftware.aspx?SoftwareReleaseUId=24567&ProductNumber=J9728A&lang=en&cc=us&prodSeriesId=3231819&SaidNumber
    However, they come back and say,
    OID 1.3.6.1.4.1.11.2.3.7.11.154 is not added to MIB database.
    According to the file hpicfOid.mib OID 1.3.6.1.4.1.11.2.3.7.11.154 has only one child OID 1.3.6.1.4.1.11.2.3.7.11.154.1:
        hpSwitchModuleJ9728A OBJECT-IDENTITY
            STATUS      current
            DESCRIPTION "The authoritative identifier for the
                         J9728A Fixed 48G module."
            ::= \{ hpSwitchJ9728A 1 }
    My question is, which MIB downloads do I send them to ensure they have all the OID definitions that they need?
    Thanks!
    Jason
  • 2.  RE: OID/MIB translation with Kiwi
    Posted Jun 18, 2019 10:45 AM
    I think that is the correct MIb file (MIBs-Nov-2018), Are you seeing any error message?
  • 3.  RE: OID/MIB translation with Kiwi
    Posted Jun 18, 2019 11:43 AM
    I also thought it was correct. They are just saying the above, that it doesn't contain all the definitions for OIDs that are missing. Is it possible that the OIDs in question (eg 1.3.6.1.4.1.11.2.3.7.11.154.2) are simply not defined at all?
    Basically I have a list of OIDs that Kiwi does not know how to interpret, then I have to find the appropriate MIB and supply it to the vendor.
    After supplying a couple of different MIBs from the download page, they were able to improve the translation, but there are still some missing. I can provide the full list of OIDs if that helps.
