On Demand Endpoint Scan not working
  • 1.  On Demand Endpoint Scan not working
    Posted Feb 27, 2019 08:54 AM
    I'm using Version 6.7.9.109195 of clearpass.
    If I'm using the "Trigger Server Action" -> "On Demand Endpoint Scan" Action from the Endpoint menu, nothing happens on the client. I checked with wireshark - no packt is comming from CPPM.
    Same behaviour if I'm using this option as an Enformenct Profile ( Target-Server = localhost, Action = On Demand Endpoint Scan)
    Client IP-Adress is correct in the enpoint repository.
    If I'm doing a network scan on the IP-Adress of the client everthing is working fine - so WMI Credentials are correct.
    Any ideas?
  • 2.  RE: On Demand Endpoint Scan not working
    Posted Feb 27, 2019 09:33 AM
    Is there an active RADIUS accounting session?
  • 3.  RE: On Demand Endpoint Scan not working
    Posted Feb 27, 2019 09:34 AM
    Yes - accounting data is received.
  • 4.  RE: On Demand Endpoint Scan not working
    Posted Feb 27, 2019 09:38 AM
    Best to work with TAC then so they can debug in realtime.
  • 5.  RE: On Demand Endpoint Scan not working
    Posted Mar 06, 2019 12:14 PM
    Hi all,
    This is a Known bug in the 6.7 version. I have open a TAC and the answer was:
    The "on demand endpoint scan"  feature introduced  have loophole recognizing ip and triggering scan,  this will be fixed in 6.8.
    Elena
  • 6.  RE: On Demand Endpoint Scan not working
    Posted Mar 07, 2019 02:02 AM
    Yes - same for me. I opend a ticked and TAC checked it on monday.
    Got the same response - it will be fixed in 6.8.
  • 7.  RE: On Demand Endpoint Scan not working
    Posted Mar 27, 2019 10:02 AM
    Just updated to 6.8.0  but the ondemand scan is still not working.
    Couldn't fint anything in the release-notes to this point and didn't get an answer from TAC.....
  • 8.  RE: On Demand Endpoint Scan not working
    Posted Jun 30, 2019 11:30 AM
    Same Here.
  • 9.  RE: On Demand Endpoint Scan not working
    Posted Nov 28, 2019 05:42 AM
    Hi!
    Is this still an issue? I'm trying out "ondemand endpoint scan".
    And I see nothing in our firewall to the endpoint IP.
    Trying to figure out if I'm doing something wrong or if it's just a bug.
  • 10.  RE: On Demand Endpoint Scan not working
    Posted Dec 03, 2019 08:43 AM
    Guess I'm having the same issue aswell.
    Nothing happens when triggered.
  • 11.  RE: On Demand Endpoint Scan not working
    Posted Jan 16, 2020 08:41 AM
    Same here. 6.8.4. I an opening a TAC case and will post findings.
  • 12.  RE: On Demand Endpoint Scan not working
    Posted Jan 16, 2020 10:47 AM
    Update. I am doing On-Demand Subnet scans. It works when launching the scan from Monitor / Profiler and Network Scan / Network Scan Results. That section also has an option to Start a scan.
    It does not work when launched from Configuration / Network Scan.
    TAC is working to reproduce in the LAB.
  • 13.  RE: On Demand Endpoint Scan not working
    Posted Jan 17, 2020 09:35 AM
    TAC Engineer had us restart the Async Network service on the publisher. This did indeed correct the issue and I can run scans from either section. Hopefully this is isolated in that it needed restarted after upgrade to 6.8.4. If I find it needs constant restart, I will re-enage TAC.
    Happy scanning :-)
  • 14.  RE: On Demand Endpoint Scan not working
    Posted Jan 30, 2020 05:00 AM
    Not sure this is the same issue ?
    Maybe the same root cause with the async service.
    But the post (and also my issue) is with ondemand endpoint scan http server action.
  • 15.  RE: On Demand Endpoint Scan not working
    Posted Jan 30, 2020 06:51 AM
    Indeed, I was looking at the Network Scan functions which also has an OnDemand Scan. Can you try restarting your Async service and see if it corrects your issue?
  • 16.  RE: On Demand Endpoint Scan not working
    Posted Feb 18, 2020 10:40 AM
    Hi!
    Sorry been very busy. Today I restarted async service and made no difference. I see no traffic from clearpass to client in the firewall.
    Anyone managed to solve this ?
