  • 1.  Onboard Andriod Provisioning
    Posted Oct 31, 2016 07:47 PM
    I'm having issues provisioning an Andriod device (s7) with Onboard. Once I associate to the SSID I'm automatically redirected to the "Sign in to Wi-Fi networks" popup and presented with the Onboard captive portal. I then enter my credentials and click on the Quick Connect app. Here I get an error:
    "Web page not available
    The web page at market://details?id=com.arubanetworks.quickconnect.andriod could not be laoded because: net::ERR_UNKNOWN_URL_SCHEME"
    I'm using an allow any rule in my provisioning role on the controller to eliminate it filtering any traffic. I've also tried to provision my Windows 10 latop and it worked without any issues allowing me to sucecssfully install Quick connect and authenticate with EAP-TLS.
    I've also seen a post here from 6 years ago stating that the error is related to the browser not having an application association to the google play store. I've tried with both chrome and IE being my default applicationw without success. Under Application Info>Google Play Store>Set as Default it reads "None set as default", when I click into this under "App links" it's set to "Go to supported URLs"--> "Via this app" and under "Supported web addresses"-->search, play.google.com and market.andriod.com.
    Has anyone come across this issue before? Any help is appreciated.
  • 2.  RE: Onboard Andriod Provisioning
    Posted Nov 01, 2016 10:54 PM
    Have you tried putting the device in the authenticate role to see if it allows the access.  My "authenticate" role allows any any all.
    Also have you tried using a difference Android device like an s6?
    Do a "show datapath session table (your android ip)" and look for Y and D flags while trying to access the playstore.
  • 3.  RE: Onboard Andriod Provisioning
    Posted Nov 07, 2016 06:06 PM
    Yep it was a role issue, my role didn't have the correct Android white list in the provisioning role:
    Thank you
  • 4.  RE: Onboard Andriod Provisioning
    Posted Mar 02, 2017 10:46 PM
    HI Nart1,
    can you share the way you done this settings on the controller please. Even though I configured any any rule on ACL, my Android tabs cant download the app " quick connect" from the play store.
