  • 1.  OnConnect Enforcement with HPE Comware
    Posted Feb 07, 2018 06:34 AM
    On p17 of "Wired Policy Enforcement Solution Guide" it is mentioned that OnConnect is a new feature (ClearPass 6.6.1 and onwards) enabling SNMP-based enforcement.
    It is not mentioning firmware release LAN switches (HPE 3500, 3800, and 8206 in our case) should be running on, so I was wondering if this feature will work on any old one (from K.16.02 to KA 15.12)? Thanks in advance.
    NesaM
  • 2.  RE: OnConnect Enforcement with HPE Comware
    Posted Feb 07, 2018 07:36 AM
    The title of your thread says HPE Comware. Comware is not supported today but will be soon.
    Regarding legacy HPE ProVision, we have only tested ArubaOS-Switch code (16+) but the older code *should* work.
  • 3.  RE: OnConnect Enforcement with HPE Comware
    Posted Feb 07, 2018 07:50 AM
    Hi Tim,
    Thank you for clarifying this, appreciated.
    NesaM
