  • 1.  Onguard testing
    Posted Jan 30, 2014 09:50 PM
    Hi there,
    I'm testing onboarding but keep getting this error:
    EAP-PEAP: fatal alert by client - access_denied
    Any suggestions what may be the cause or what I may not have configure corectly?
    Thanks.
  • 2.  RE: Onguard testing
    Posted Jan 30, 2014 09:52 PM
    We're going to need more information. What type of device
    CPPM version
    Do you have a publicly signed cert
    Etc
    The error you have means the client do sent trust the server cert
  • 3.  RE: Onguard testing
    Posted Jan 30, 2014 10:09 PM
    What type of device: laptop
    CPPM version: 6.2.4.55896
    Do you have a publicly signed cert: yes we do.
    We have 2 SSIDs, Nexus (for guest) and Kumul (for staff)
    When I try to onboard someone this is what happens.
    1. Connect to Nexus SSID.
    2. Download quick connect app.
    3. Run the app.
    4. Enter credentials.
    5. Message on the app: Configuring your system….your system has been successfully configured...you can connect to the secure network Kumul or click Finish to exit.
    6. A) I click connect and get the message: authentication in progress (on the app) + pop up message on windows “additional information is needed to kumul”
    After a little while message on app is: could not authenticate with wireless network and then another message says: Error, quick connect encountered an error condition. The log for your configuration session can be found here(refer attached).
    B) If I just finish and then later click on ssid Kumul, I get msg: Network Authentication, please enter user credentials.
    I. When user credentials entered
    II. Pop up message: windows was unable to connect to Kumul
    ***On CPPM, I see the device under: Identity>Onboard devices
    Under live monitoring>Access tracker, login has been rejected, Alert for this request: EAP-PEAP: fatal alert by client - access_denied. (this is a new laptop Im trying to onboard, on my laptop, I deleted the installed certificates but issue still exists)
    Remigius Ketoma
    Graduate Network Engineer | Information Technology | Telikom PNG Limited
    d: +675 3005102 | m: +675 77583257 | f: +675 3259590 | e: remigius.ketoma@telikompng.com.pg
    [cid:image09c613.JPG@4e6ec3db.49991bc4]
    [cid:image926c7c.GIF@2d2a80c3.4db3a4e1]Please consider the environment before printing this email message.
    This e-mail and any attachments may contain confidential and
    privileged information. If you are not the intended recipient,
    please notify the sender immediately by return e-mail, delete this
    e-mail and destroy any copies. Any dissemination or use of this
    information by a person other than the intended recipient is
    unauthorized and may be illegal.
  • 4.  RE: Onguard testing
    Posted Jan 30, 2014 10:21 PM
    Ok so Im a little confused here.
    Are you onboarding and or using quick connect?
    If your onboarding are you handing out a TLS cert or just doing PEAP.
    If its just PEAP you might just have a trust issue since you are using a publicly signed cert. You will need to either combine the cert with the root and intermediate like Pic 1 or you need to just add all the certs in the trust settings in pic 2
