You would need to configure the SSID with Enhanced Open and enable transition mode to get a legacy open unencrypted SSID on 2.4 and 5GHz.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: May 14, 2025 08:45 AM
Subject: Open SSID wigh 6GHz enabled
Thank you Herman,
I want to configure the SSID to be broadcasted over the three bands. and the authentication to be from CPPM captive portal. So, what are the required configs to achieve this task.
Original Message:
Sent: May 14, 2025 04:36 AM
Little more background: 6GHz requires the WPA3 suite of security, and does not support traditional open WLAN networks. Enhanced Open is a similar technology in that the end user does not need to authenticate (or use a captive portal), but the connection is individually encrypted. Because 6 GHz is a new WLAN band, no backward compatibility is needed to support older clients.
If you configure an SSID with the type 'Open', and have it enabled on all bands, the SSID will NOT broadcast on 6GHz.
If you configure an SSID with the type 'Enhanced Open', the SSID will broadcast on 6GHz; with 'Transition mode' enabled, there will be on 2.4GHz and 5 GHz also a traditional open network be broadcasted for old clients that don't support Enhanced Open.
Original Message:
Sent: May 13, 2025 11:19 AM
Hello dears,
Is it possible to create an open SSID with 6GHz band enabled on it ?
I'm using Aruba9240 and OS version: ArubaOS 8.10.0.14
