  • 1.  Optimal signal parameters
    Posted Mar 15, 2017 11:25 AM
    Hello to all,
    I am looking for some document about the optimal values ​​of signals to be determinal if the parameters that I get in my wifi network are good. Do you know any?
    thanks in advance
  • 2.  RE: Optimal signal parameters
    Posted Mar 16, 2017 05:19 AM
    Every environment is different, so the signal parameters will always be different.   The Aruba feature ARM will adjust these to find the best settings for you.   However if using directional based antenna it best to adjust the signal parameters manually.
  • 3.  RE: Optimal signal parameters
    Posted Mar 16, 2017 05:48 AM
    I would take a look at our validated reference design library here:.http://community.arubanetworks.com/t5/Validated-Reference-Design/tkb-p/Aruba-VRDs to see if any documents favor your type of deployment. There are suggestions for parameters in those documents.
  • 4.  RE: Optimal signal parameters
    Posted Mar 16, 2017 06:14 AM
    thanks for the info, will be very usefull
