Comware
  • 1.  OSPF import-route direct not working when using vpn-instance
    Posted Feb 06, 2019 09:26 AM
    Hi All
    I am using some 5820X 24XG SFP+ (JC102A) running OSPF with multiple vpn-instances. I have some trouple with the import-route direct command, it works fine for the OSPF instance running without a vpn-instance, but for the other OSPF instances running a vpn-instance it wont import the routes and i need to configure the networks manually.
    I have tried searching but can't seem to find any answers, so I hope that you can help me :)
    Best regards
    Danny
  • 2.  RE: OSPF import-route direct not working when using vpn-instance
    Posted Feb 10, 2019 04:04 AM
    Hello Danny,
    Good day!
    Can you check below community post.
    https://support.hpe.com/hpsc/doc/public/display?docId=mmr_sf-EN_US000005304
    I believe to allow external routes in ospf database we need to add command "vpn-instance-capability simple "
    Thanks!
    I am an HPE Employee
  • 3.  RE: OSPF import-route direct not working when using vpn-instance
    Posted Feb 11, 2019 02:18 AM
    Hello
    Thanks alot for the reply :)
    I will test it later today
  • 4.  RE: OSPF import-route direct not working when using vpn-instance
    Posted Feb 11, 2019 02:33 AM
    I am happy to inform that it works now. Thanks alot.
  • 5.  RE: OSPF import-route direct not working when using vpn-instance
    Posted Feb 29, 2020 02:12 PM
    I'm using HP Comware 7 and using ospf version 2 under multiple vpn-instance.
    For one vpn-instance named MPP,  the ospf routes are not reflecting under my vpn-instance routing table MPP.
    I can see these ospf routes in my ospf database table using the "dispaly ospf lsdb"
    Why is that some ospf routes are reflectinf and some are not under my vpn-instance routing table MPP?
    Will adding the command "vpn-instance-capability simple" under my ospf fix this issue?
