Hi Friends,
Client is having his own inhouse OTP system. His requirement is that
Any user with laptop (inbuilt wireless card) should be able to connect to Wi-Fi after being authenticated with his OTP solution(user will be first authenticated using username and password and message will be sent to user with OTP, if user enters correct OTP, user will be authenticated). So its a 2 way authentication.
So the process will be like follows:-
1) Users put in their credentials which is received by OTP solution, which is inturn integrated with AD to check if username exists.
2) when Username password matches, OTP solution will send an sms to the user.
My concern is that how can we integrate Aruba Controller with this OTP, which uses radius as protocol.
Even if its integrated with controller, where will the end client put the OTP received from the OTP server
GUYS please help, it a very crucial deal!
