Comware
  • 1.  Outbound SIP calls failing with MSR2004 router and nat
    Posted May 28, 2018 02:18 PM
    I set up an MSR 2004 router for one of my customers. Generally speaking, I'm super happy with the router. However, I can't get the outbound telephony to work. When I dial a number on one of the sip phones, the call ususally just times out without being created at all. Inbound calls are working, so I think it might be a problem with nat, not translating the udp ports properly. But I have no idea how to fix it. I already tried to enable nat alg for sip without success. I need to fix this asap, so any suggestion would be much appreciated.
    #SIP
    #NAT
    #ms2004
    #outbound
  • 2.  RE: Outbound SIP calls failing with MSR2004 router and nat
    Posted May 31, 2018 02:36 PM
    I tested another router with which everything works fine. So now I'm sure that the MSR2004 is to blame.
    I did some more digging and it looks like UDP packets in general are somehow mistreated by the nat. Is there any additional option I need to configure to mimic 'stateful' routing/nating if my UDP packets?
    Here is the sanitized config that's currently active:
         version 7.1.064, Release 0605P20
         sysname gw-1
         ip icmp source 192.168.100.1
        nat address-group 0
         address xxx.91.227.170 xxx.91.227.170
         nat mapping-behavior endpoint-independent
         dhcp enable
         dns proxy enable
         dns server 8.8.8.8
         dns server 8.8.4.4
         password-recovery enable
        vlan 1
        vlan 10
         name Management VLAN
        vlan 11
         name Internal VLAN
        vlan 12
         name Guest Wifi VLAN
        vlan 20
         name Sublet 1 VLAN
        qos map-table dscp-lp
         import 6 export 6
        traffic classifier highprio operator and
         if-match acl name sip
        traffic behavior communication
        traffic behavior highprio
         remark local-precedence 7
        qos policy communication
         classifier highprio behavior highprio
         stp mode rstp
         stp global enable
        dhcp server ip-pool guest
         gateway-list 192.168.210.1
         network 192.168.210.0 mask 255.255.255.0
         address range 192.168.210.10 192.168.210.200
         dns-list 192.168.210.1
         expired day 0 hour 4
        dhcp server ip-pool internal
         gateway-list 192.168.200.1
         network 192.168.200.0 mask 255.255.254.0
         address range 192.168.200.10 192.168.201.200
         dns-list 192.168.200.1
         expired day 0 hour 8
        controller Cellular0/0
        interface Aux0
        interface NULL0
        interface Vlan-interface10
         ip address 192.168.100.1 255.255.255.0
        interface Vlan-interface11
         ip address 192.168.200.1 255.255.254.0
         packet-filter 3000 inbound
         qos apply policy communication inbound
        interface Vlan-interface12
         ip address 192.168.210.1 255.255.255.0
         packet-filter 3001 inbound
        interface Vlan-interface20
        interface GigabitEthernet0/0
         port link-mode route
         ip address xxx.91.227.170 255.255.255.248
         tcp mss 1460
         packet-filter name external inbound
         nat outbound address-group 0 port-preserved
        interface GigabitEthernet0/1
        interface GigabitEthernet0/2
        interface GigabitEthernet0/27
        interface GigabitEthernet0/3
         port link-mode bridge
         port link-type hybrid
         port hybrid vlan 10 to 12 tagged
         port hybrid vlan 1 untagged
        interface GigabitEthernet0/4
        interface GigabitEthernet0/5
        interface GigabitEthernet0/6
        interface GigabitEthernet0/7
        interface GigabitEthernet0/8
        interface GigabitEthernet0/9
        interface GigabitEthernet0/10
        interface GigabitEthernet0/11
         port hybrid vlan 10 to 11 tagged
        interface GigabitEthernet0/12
        interface GigabitEthernet0/13
        interface GigabitEthernet0/14
        interface GigabitEthernet0/15
        interface GigabitEthernet0/16
        interface GigabitEthernet0/17
        interface GigabitEthernet0/18
         port hybrid pvid vlan 10
        interface GigabitEthernet0/19
        interface GigabitEthernet0/20
        interface GigabitEthernet0/21
        interface GigabitEthernet0/22
        interface GigabitEthernet0/23
        interface GigabitEthernet0/24
        interface GigabitEthernet0/25
         port access vlan 11
        interface GigabitEthernet0/26
         port access vlan 10
         scheduler logfile size 16
        line class aux
         user-role network-admin
        line class tty
         user-role network-operator
        line class vty
        line aux 0
        line vty 0
        line vty 1
         authentication-mode scheme
        line vty 2 63
         ip route-static 0.0.0.0 0 xxx.91.227.169
         ssh server enable
         ssh user admin service-type all authentication-type password
         ssh2 algorithm cipher aes256-cbc
         ntp-service unicast-server ptbtime1.ptb.de
        acl advanced 3000
         rule 0 deny tcp destination 192.168.100.0 0.0.0.255
         rule 1 deny udp destination 192.168.100.0 0.0.0.255
        acl advanced 3001
         rule 0 deny ip destination 192.168.100.0 0.0.0.255
         rule 1 deny ip destination 192.168.200.0 0.0.0.255
        acl advanced name external
         rule 0 permit icmp
         rule 5 permit tcp established
         rule 15 permit udp source-port eq dns
         rule 20 permit udp destination-port gt 1024
         rule 21 permit udp
         rule 25 permit 115
         rule 9999 deny ip
        acl advanced name sip
         rule 0 permit tcp destination-port range 5060 5061
         rule 5 permit udp destination-port range 5060 5061
        domain system
         domain default enable system
        role name level-0
         description Predefined level-0 role
        role name level-1
         description Predefined level-1 role
        role name level-2
         description Predefined level-2 role
        role name level-3
         description Predefined level-3 role
        role name level-4
         description Predefined level-4 role
        role name level-5
         description Predefined level-5 role
        role name level-6
         description Predefined level-6 role
        role name level-7
         description Predefined level-7 role
        role name level-8
         description Predefined level-8 role
        role name level-9
         description Predefined level-9 role
        role name level-10
         description Predefined level-10 role
        role name level-11
         description Predefined level-11 role
        role name level-12
         description Predefined level-12 role
        role name level-13
         description Predefined level-13 role
        role name level-14
         description Predefined level-14 role
        user-group system
        local-user admin class manage
         password hash xxx
         service-type ssh telnet terminal http
         authorization-attribute user-role network-admin
         authorization-attribute user-role network-operator
        cwmp
         cwmp enable
        return
  • 3.  RE: Outbound SIP calls failing with MSR2004 router and nat
    Posted Mar 16, 2020 04:20 AM
    Well, this looks like a huge issue and I don't really know how to fix this. But I have a friend, a friend that is working in an Internet provider company and as far as I know, he was always telling me that, if I have issues with my router or with the internet connection I should seek for the answer on the internet for the first time, before calling the provider, as many of the issues could be solved very easy. Also, my friend told me that everybody should read this article about high-speed internet connections if you want to understand how does an internet connection work. Maybe you will find a solution for your problem after reading this article, I will be honest with you, this is the greatest article I ever read and I found out a lot of new features and tips that are very useful on a day by day basis.
