Unforunately I have not made any progress on queue counters. But I can get counters on my traffic behaviors for example:
traffic behavior MARK_AF41
remark dscp af41
remark local-precedence 4
remark drop-precedence 0
accounting packet
[switch]display qos policy interface GigabitEthernet 1/0/0/45
Interface: GigabitEthernet1/0/0/45
Direction: Inbound
Policy: QOS_POLICY
Classifier: CITRIX
Operator: AND
Rule(s) : If-match acl name CITRIX
Behavior: MARK_AF41
Marking:
Remark DSCP af41
Marking:
Remark local precedence 4
Marking:
Remark drop precedence 0
Accounting Enable:
409833511 (Packets)
I will offer up some of my learnings with the output queues. One not so well documented fact (at least on my 10508) is that output queues are only filled up using a local-precedence values (0-7). For example if I mark inbound traffic as af41 the switch will not change the output queue. What I need to do is mark my traffic inbound as af41 and also local-precedence 4 and drop-precendece 0 (seen in the config above). This will place the traffic in output queue 4 as it leaves an interface. I can then mess with the wrr or wfq settings on the outbound port to influence the flow of traffic.
Now if the traffic is already marked as af41 BEFORE it gets to my switch the mapping to local-precedence 4 and drop precedence 0 will happen automatically as long as I trust dscp, and havent altered the default map tables.
Hope that helps...
Dan
