Comware
Packets dropped due to full GBP or insufficient bandwidth
  • 1.  Packets dropped due to full GBP or insufficient bandwidth
    Posted May 06, 2020 09:09 AM
    We deploy video stream by comware switches.
    However, on the interfaces of a switch (5510), I have a lot of lost packages.
    For video it is problematic.
    On the attached image, you will have an overview of the network topology.
    Why do I have packages deleted on interfaces 1/0/4, 1/0/6, and Ten 1/0/25?
    I don't have one on the Ten 1/0/28 interface.
    I activated the "burst-mode enable" command but nothing helps.
    Here is the result of the command:
    <SW>display packet-drop interface gig 1/0/4
    GigabitEthernet1/0/4:
    Packets dropped due to full GBP or insufficient bandwidth: 6328369
    Packets dropped due to Fast Filter Processor (FFP): 0
    Packets dropped due to STP non-forwarding state: 0
    <SW>display packet-drop interface gig 1/0/6
    GigabitEthernet1/0/6:
    Packets dropped due to full GBP or insufficient bandwidth: 235369
    <SW>display packet-drop interface ten 1/0/25
    Ten-GigabitEthernet1/0/25:
    Packets dropped due to full GBP or insufficient bandwidth: 2944092
    <SW>display packet-drop interface ten 1/0/28
    Ten-GigabitEthernet1/0/28:
    Packets dropped due to full GBP or insufficient bandwidth: 0
    On the 5510 switch there are cameras plugged in and the result is the same, there are dropped packets.
    The multicast streams are in one vlan and the unicast streams of the cameras are in another vlan.
    Can you help me solve this problem?
    thanks you
    Regards
  • 2.  RE: Packets dropped due to full GBP or insufficient bandwidth
    Posted May 06, 2020 01:10 PM
    Could you please share the display version output from the device?
    Thanks!
  • 3.  RE: Packets dropped due to full GBP or insufficient bandwidth
    Posted May 06, 2020 02:15 PM
    thank you for your reply.
    [SW]display version
    HPE Comware Software, Version 7.1.070, Release 3506P02
    Copyright (c) 2010-2019 Hewlett Packard Enterprise Development LP
    HPE 5510 24G 4SFP+ HI 1-slot Switch JH145A uptime is 7 weeks, 5 days, 20
    hours, 58 minutes
    Last reboot reason : User reboot
    Boot image: flash:/5510hi-cmw710-boot-r3506p02.bin
    Boot image version: 7.1.070, Release 3506P02
    Compiled Dec 16 2019 11:00:00
    System image: flash:/5510hi-cmw710-system-r3506p02.bin
    System image version: 7.1.070, Release 3506P02
    Feature image(s) list:
    flash:/5510hi-cmw710-freeradius-r3506p02.bin, version: 7.1.070
    Slot 1:
    Uptime is 7 weeks,5 days,20 hours,58 minutes
    5510 24G 4SFP+ HI 1-slot Switch with 2 Processor
    BOARD TYPE: 5510 24G 4SFP+ HI 1-slot Switch
    DRAM: 1984M bytes
    FLASH: 512M bytes
    PCB 1 Version: VER.A
    Bootrom Version: 127
    CPLD 1 Version: 003
    Release Version: HPE 5510 24G 4SFP+ HI 1-slot Switch JH145A-3506P02
    Patch Version : None
    Reboot Cause : UserReboot
    [SubSlot 0] 24GE+4SFP Plus
    Regards
  • 4.  RE: Packets dropped due to full GBP or insufficient bandwidth
    Posted May 06, 2020 06:17 PM
    It seems the device is running on latest software. Generally GBP Full bandwidth issue get resolve after enabling the burst mode but its already implemented.
    1. Can you please check physical connectivity between interfaces 1/0/4, 1/0/6, and Ten 1/0/25 and end devices.
    2. Please upgrade the NIC driver on conencting end devices.
    3. If still problem persist then capture packets or log a ticket with support.
    Thanks!
  • 5.  RE: Packets dropped due to full GBP or insufficient bandwidth
    Posted May 20, 2020 12:19 PM
    Has my solution helped you resolve the query or do you need more assistance?
    Thanks!
  • 6.  RE: Packets dropped due to full GBP or insufficient bandwidth
    Posted May 22, 2020 02:52 AM
    Thank you for your reply.
    I have checked the connection on the cable and the drivers for the network cards are up to date. Is it possible to add more memory to the port buffers?
    There is available memory.
    <SW>display memory
    Memory statistics are measured in KB:
    Slot 1:
                                 Total                     Used           Free        Shared       Buffers          Cached       FreeRatio
    Mem:                    2002116                424540      1577576             0          2744          154840              79.6%
    -/+ Buffers/Cache:                             266956       1735160
    Swap:                               0                          0                  0
    LowMem:            1477828                 168876       1308952        --              --                   --                     88.6%
    HighMem:            524288                 255664       268624         --              --                   --                      51.2%
    What do you think ?
  • 7.  RE: Packets dropped due to full GBP or insufficient bandwidth
    Posted Sep 13, 2020 03:51 AM
    i have same issue with hp 10500 (7.1.045, Release 7183) but i did not found command burst-mode
    any idea what is solution
    #10500
  • 8.  RE: Packets dropped due to full GBP or insufficient bandwidth
    Posted Sep 13, 2020 04:14 AM
    Can you please try like this:
    [HPE-10500] burst-mode enable chassis <chassis number> slot <slot number>
    But there are possibility that some of the Line card wont support this command.
    Thanks!
  • 9.  RE: Packets dropped due to full GBP or insufficient bandwidth
    Posted Sep 13, 2020 06:00 AM
    thanks , i tried before but burst-mode  not recongized command
  • 10.  RE: Packets dropped due to full GBP or insufficient bandwidth
    Posted Sep 23, 2020 03:35 AM
    There are some series card's doesn't support this command.
    Also.I believe the device is running on latest software version.
    Thanks!
  • 11.  RE: Packets dropped due to full GBP or insufficient bandwidth
    Posted Sep 07, 2021 08:59 AM
    Hello. I have this problem. I have enabled the following commands on my core switch (HP 10508):
    system-view
    burst-mode enable chassis 1 slot 1
    burst-mode enable chassis 2 slot 1
    burst-mode enable chassis 1 slot 2
    burst-mode enable chassis 2 slot 2
    burst-mode enable chassis 1 slot 3
    burst-mode enable chassis 2 slot 3
    As you can see, we have an irf cluster consisting of two chassis.
    After doing this, all the problems related to 1 Gbps have disappeared, no packet drops outbound and inbound associated to card supporting 1 Gbps interfaces..
    But We have 4 slots with ten-gigabitethernet. Irf interfaces belong to these slots, as well as firewalls, synergy, etc.
    Many packets drops are found on these interfaces and I don't know how to avoid them. I know packet drops are normal on irf interfaces, but I'm worried because many of packet drop bursts are related to firewall interfaces (Check Point firewalls in cluster mode).
    These bursts affect snmpget queries and icmp on my network.
    Is there another mechanism to avoid these bursts in slots that do not support "burst mode"?
  • 12.  RE: Packets dropped due to full GBP or insufficient bandwidth
    Posted Sep 07, 2021 09:38 AM
    Hello @JUANTRON ,
    Is it a 10gig module?
    Can you share the product number 'JXXXX" of 10gig module and chassis?
    Is chaasis on latest software version, because sometimes packet drop issues might be others?
    Also check if there are no layer 1 issues.
    Thanks!
  • 13.  RE: Packets dropped due to full GBP or insufficient bandwidth
    Posted Sep 08, 2021 12:18 PM
    I can't apply "burst mode" feature in the following cards:
    HP A10500 16-port 10-GbE SFP+ SC Module JC628A (BOARD TYPE: LSU1TGS16SC0)
    HPE 10500 16p 1/10GbE SFP+ SF Mod JH193A (BOARD TYPE: LSUM2TGS16SF0)
    But "burst mode" is applied in the following cards:
    HP A10500 48-port Gig-T SE Module JC618A
    HP 10500 16p GbE SFP/8p GbE Cmbo SE Mod JC763A
    My two chassis are:
    HP A10508 Switch Chassis JC612A
    There are no layer 1 issues.
    <CSALUD-SEV-001-SWLAN50>display version
    HPE Comware Software, Version 7.1.070, Release 7585P07
    Copyright (c) 2010-2020 Hewlett Packard Enterprise Development LP
    HP 10508 uptime is 25 weeks, 5 days, 21 hours, 11 minutes
    Last reboot reason : USER reboot
    Boot image: flash:/10500-CMW710-BOOT-R7585P07.bin
    Boot image version: 7.1.070, Release 7585P07
    Compiled Jan 14 2020 11:00:00
    System image: flash:/10500-CMW710-SYSTEM-R7585P07.bin
    System image version: 7.1.070, Release 7585P07
    Can I apply cut-through to avoid packet drops? And, how?
    "cut-through enable" command is not recognized (irf cluster mode)
