Paging is Layer 2 Multicast to start , and if youhave a . You do not state if its layer 2 or layer telephones on your network . You say some tels are not recieving a page ? Are they all on the same subnet and/or network ?
I would suggest to start :
1. Reboot the NBX
2. Reboot the switches ( I assume you have a small network )
3. If it still does not work , we need the following :
NBX version of code you are running
Type of telephones on your network . 2102 . 3102 etc .
Type of switches on your network 3Com 4400 , etc ..
IGMP set up ion the switches ? Multicast set up ....
Are you running IP on the Fly ? NBX Protocol Mode ....
Are your telephones running at Layer 2 or Layer 3 ? ( Do your tels have IP addresses assigned to them in a different subnet ? )
