Painting AP-ANT-45 - has anyone measured loss when painting APs or antennas?
  • 1.  Painting AP-ANT-45 - has anyone measured loss when painting APs or antennas?
    Posted Jun 07, 2021 10:41 AM
    I've seen KBs and discussions here that it's OK to use primer and top coat spray paint to let antennas and outdoor APs hide.
    What I wonder is has anyone tried this on an AP-ANT-45 (used with a AP-514 in my case), and have they done "before and after" tests to see how many dB is lost in the painting?
    I can throw an extra dB or so in my wireless calculators for this site, but I wonder if anyone has any real data on what a light spray of primer and top coat latex would do to the signal.
    Ambi
    Lawrence Brandt
  • 2.  RE: Painting AP-ANT-45 - has anyone measured loss when painting APs or antennas?
    Posted Jun 08, 2021 06:04 AM
    As far as I know, the attenuation of paint on an antenna is neglectable. As long as you stick to non-metallic paints.
    Possibly others have actually measured it, I would estimate this effect too marginally to effectively measure.
