  • 1.  PAPI_Send: sendto ARM Process failed resulting in 100% CPU
    Posted Feb 13, 2015 07:26 AM
    I have a small network (3 APs) of AP-105 that regulary goes into 100% CPU at the master:
    Feb 13 13:18:04  stm[1658]: PAPI_Send: sendto ARM Process failed: No such file or directory Message Code 3115 Sequence Num is 36833
    Feb 13 13:18:04  stm[1658]: <304065> <ERRS> |AP AP-Attic@91.206.175.220 stm|  PAPI_Send failed, send_papi_message_with_args, 790: No such file or directory, dstport 8494
    Only way to get back to normal CPU load is to reboot the master. Anyone seen this?
    I'm running 6.4.2.3-4.1.1.2.
  • 2.  RE: PAPI_Send: sendto ARM Process failed resulting in 100% CPU
    Posted Feb 17, 2015 07:56 PM
    Have you opened up a case?
  • 3.  RE: PAPI_Send: sendto ARM Process failed resulting in 100% CPU
    Posted Feb 18, 2015 01:03 AM
    No, I have not.
    jakob
  • 4.  RE: PAPI_Send: sendto ARM Process failed resulting in 100% CPU
    Posted Mar 03, 2015 09:12 AM
    we are seeing similiar behaviours, but this in the system log:
    Mar  3 14:07:10  stm[1549]: <304065> <ERRS> |AP INSE696.1.2@10.2.103.27 stm|  PAPI_Send failed, send_papi_message_with_args, 790: No such file or directory, dstport 8494
    Mar  3 14:07:41  stm[1549]: <304065> <ERRS> |AP INSE696.1.2@10.2.103.27 stm|  PAPI_Send failed, send_papi_message_with_args, 790: No such file or directory, dstport 8494
  • 5.  RE: PAPI_Send: sendto ARM Process failed resulting in 100% CPU
    Posted May 08, 2015 01:48 AM
    Any one can help me understand what this msg actually means?
    Our Aruba controller keep on taking down its wan lin after this msg.
    PAPI_Send: sendto License Manager failed: No such file or directory Message Code 0 Sequence Num is 20.
    fpapps[3357]: <209801> <WARN> |fpapps|  Physical link down: port 0/0/2
    Akram.
  • 6.  RE: PAPI_Send: sendto ARM Process failed resulting in 100% CPU
    Posted May 08, 2015 07:02 AM
    please upgrade the firmware you are using has been known to be problematic.
    My suggestion is to go to 4.1.1.5, it contains a lot of bug fixes.
