  • 1.  Parameters Aruba controller
    Posted Oct 21, 2019 10:18 AM
    Hello i got a question
    it is possible to change these paramethers like in the fortigate firewall on aruba mobility controller?
    tcp-halfclose-timer 30
    tcp-halfopen-timer 30
    tcp-timewait-timer 0
    udp-idle-timer 60
    i got a client asking me if ithat is possible.
    Chees
    Carlos
  • 2.  RE: Parameters Aruba controller
    Posted Oct 21, 2019 11:08 AM
  • 3.  RE: Parameters Aruba controller
    Posted Oct 21, 2019 11:32 AM
    Thanks you Collin!!
    Cheers
    Carlos
  • 4.  RE: Parameters Aruba controller
    Posted Oct 28, 2019 11:44 AM
    Hello Collin
    The client asked if this is possible in the clearpass, i bealive is not because the clearpass is not a firewall, but just asking just in case.
    Cheers
    Carlos
