  • 1.  Patch Management Grace period
    Posted Apr 28, 2015 08:55 AM
    Hi
    is anyone using the grace period with the windows patch management posture checking? I have it configured to check Microsoft Windows AutomaticUpdates for security patches only, which identifies when machines have outstanding patches but it imediately quarantines the machine despite have a Grace Period of 3 weeks configured.
    Am I missing something, I can't find any information on it.
  • 2.  RE: Patch Management Grace period
    Posted Apr 28, 2015 09:01 AM
    Here is the information that I found in the Help system in CPPM 6.5. Not sure if this helps, but it's a good place to start:
  • 3.  RE: Patch Management Grace period
    Posted Apr 28, 2015 09:22 AM
    Thanks Zach
    Looking at that I have everything set correctly and it should work, no sign of a grace period being applied though.
  • 4.  RE: Patch Management Grace period
    Posted Jul 13, 2018 11:23 AM
    Hi G1J... Have you figured out the issue?
