If google has correctly translated your question, you want to know why a wireles device does not become green in WLAN topology when an alarm is cleared. There are different toplogy views that can display wireles devices.
To show this I have attached some PNGs showing an AP shutdown and restarted.
The MSM560 AP is one of the APs managed by a MSM765 Wireless LAN controller. I also have added it as a discovered IP device.
I turn off Power to the device by disable PoE on the switch port. You can see how the Custom Toplogy view and WIreless topolgy view show this event. I then restore PoE.
The custom topology uses Ping to check state, and responds quickly, going green to red and then red to green.
The wireless topolgies look different, and use the data from SNMP to determine state. This must synchronize and refresh so it is slower to react.
Some alarms change state automatically and some require recovery. If your recovered alarms do not clear perhaps something with SNMP configuration?
A screenshot of yours would help. Hopefully English to French translation is OK. Sorry if I misunderstand your problem.
