PC dot1x authentication via IP phone second port/data port
  • 1.  PC dot1x authentication via IP phone second port/data port
    Posted Mar 19, 2015 11:11 AM
    Hi All, I need some advice from you guys.
    I've deployed dot1x wired authentication with clearpass in a site. It's works well with switches but today I received an report from users that part of them failed to perform dot1x wired authentication when the notebook plugged into the IP phone second port/data port. Remark: the IP phone is connecting to the switches as well.
    I have no clue on this. May I know does the IP phone required dot1x support in order to make this works? Or list in the IP of the IP phone into the clearpass will do?
  • 2.  RE: PC dot1x authentication via IP phone second port/data port
    Posted Mar 19, 2015 11:13 AM
    What type of switch?
  • 3.  RE: PC dot1x authentication via IP phone second port/data port
    Posted Mar 19, 2015 11:17 AM
    Most of the switches is cisco 2960 and 3750.
    I don't have the record of IP phone model.
  • 4.  RE: PC dot1x authentication via IP phone second port/data port
    Posted Mar 19, 2015 08:29 PM
    You'll need to configure the switchport with 802.1X authentication. If you don't want to do 1X for the phone, configure 802.1X with MAC-auth bypass (MAB).
