  • 1.  PCM+2.3 and AP530 configuration
    Posted Oct 30, 2008 10:04 AM
    Does PCM+2.3 collect and save the AP530 configurations (and the history too) like the LAN switches?
    My discovered 530 have no configuration saved.
    A useful feature in PCM is to have all switches configurazions in a safe place ready to deploy to a brand new switch.
  • 2.  RE: PCM+2.3 and AP530 configuration
    Posted Oct 31, 2008 05:47 AM
  • 3.  RE: PCM+2.3 and AP530 configuration
    Posted Nov 04, 2008 04:01 AM
    Well, I'm running PCM+2.3upd7.
    How could I try Mobility Manager?
    The available download is a zip file that contains a massive 454MB exe file.
    I neither dare to install it on the working server, not build a new server only to do a test.
    Someone could suggest how could I install the MM trial only on the working server?
    Thanks!
  • 4.  RE: PCM+2.3 and AP530 configuration
    Posted Nov 04, 2008 09:01 AM
    procurve mobility manager work is a pluging on PCM+
    my advice
    you can create new small test network a few 530 and a few switch.
    you can new install pcm+ and mobility manager (30 day free demo)on different pc and test your small test network .
    for download pcm+ and mobility maneger(30 day free demo)
    http://www.hp.com/rnd/software/network_management.htm
  • 5.  RE: PCM+2.3 and AP530 configuration
    Posted Nov 04, 2008 09:22 AM
    Ok, I would prefer a real plug-in to test MM on the working server.
    Anyway, I will test MM on a brand new PCM-MM installation.
    Thanks.
  • 6.  RE: PCM+2.3 and AP530 configuration
    Posted Mar 29, 2010 08:11 AM
    Now I have PCM+ 3.10 and Mobility Manager.
    How could I save the AP530 configurations?
    PCM Admin Guide (5990-8850a) doesn't help.
  • 7.  RE: PCM+2.3 and AP530 configuration
    Posted Mar 31, 2010 08:07 AM
    Right click on the AP530 in the list.
    Choose Config Manager > Export Configurations
    Hope this is what you need.
    Best regards
