I am having 2 HP9000 servers running 11.11 and 11.0 which are on DNS and communicating with all nodes on the network. I would like to transter large amount of data from one server to another without consume a lot of community bandwidth. I am thinking of setting up a peer-to-peer network just between the two server, possibly add an extra network card on each server and use a cross-over cable. My questions:
How do I configure this in /etc/rc.config.d/netconf?
Once the communication is established, I will have to exportfs the filesystems from one system so the other system can mount to and copy the data. Is there other way of transfering data without using NFS because NFS is slow?
Just an idea. I don't know if it is feasible or not. Had anybody done this before or have any idea how to do this? Please help. I appreciate your input.
Thank you,
Tuan Nguyen
