  • 1.  Phone number validation
    Posted Feb 28, 2013 09:47 AM
    To check the guest's phone numbers, I use the validator "NwaSmsIsValidPhoneNumber". It works fine but now I need to force guests to add a + before the number. Like +044234657890
    How can I do this ?
    Dimitri
  • 2.  RE: Phone number validation
    Posted Feb 28, 2013 12:55 PM
    Change the Validator to IsRegExMatch and use this regex:
    ^\+(?:[0-9] ?){6,14}[0-9]$
    That should enforce the E.164 standard.
  • 3.  RE: Phone number validation
    Posted Mar 01, 2013 01:59 AM
    Thanks, I will try it.
    Dimitri
  • 4.  RE: Phone number validation
    Posted Mar 07, 2013 03:45 AM
    A fast feedback, working fine thanks.
    Dimitri
  • 5.  RE: Phone number validation
    Posted Apr 16, 2013 10:44 AM
    I need a new regex that checks that there are only numbers with no spaces and max lenght is 15 digits. Anyone can help me, thanks.
    Regards
    Dimitri
  • 6.  RE: Phone number validation
    Posted Apr 16, 2013 02:50 PM
    Many regex testers and libraries out there mate. [0-9]{15} is the simple answer.
  • 7.  RE: Phone number validation
    Posted Apr 17, 2013 02:22 AM
    Ok thanks, it's allright.
  • 8.  RE: Phone number validation
    Posted Apr 17, 2013 03:43 AM
    Try using /^\d\d\d-\d\d\d-\d\d\d\d$/ You just need to remove the - if you don't want the standard US format
  • 9.  RE: Phone number validation
    Posted Apr 17, 2013 03:44 AM
