PLACE A PHONE IN ITS VLAN WITH LLDP MED
  • 1.  PLACE A PHONE IN ITS VLAN WITH LLDP MED
    Posted Aug 06, 2018 11:17 AM
    Hello.
    I am a beginner in configuring Aruba controllers. I have simple configurations.
    I have to configure an Aruba controller 7010 and I want to make a rule so when I connect a computer to a wired port it has to be in VLAN 1, but when it is an IP Phone, it has to be placed in VLAN 20. I have configured such a rule in a Cisco switch, but I cannot achieve the same result with the Aruba controller 7010. I am using LLDP MED.
    I have configured the next commands:
    configure terminal
    vlan 20
    ap lldp med-network-policy-profile Voice20
    application-type voice
    tagged
    l2-priority 7
    vlan 20
    dscp 46
    ap lldp profile P_Voice20
    lldp-med-network-policy-profile Voice20
    ap wired-port-profile WP_Voice20
    lldp-profile P_Voice20
    interface gigabitethernet 0/0/10
    lldp receive
    lldp transmit
    lldp med
    exit
    This is the configuration I have found in many sites, but the IP Phone does not place in VLAN 20.
    I have some doubts:
    1. How does the controller know the profile has to be assigned to a specific port?
    2. Does it mind whether the port is trusted or untrusted?
    3. The main question: Why does not it work? Can anyone help me?
    The AOS version is 6.5.0.0.
    The IP Phone is connected to port 0/0/10
    (Aruba7010) #show lldp neighbor interface gigabitethernet 0/0/10 detail
    Interface: GE0/0/10, Number of neighbors: 1
    Chassis id: 192.168.92.50
    Interface description: WAN PORT, ID: 00:15:65:46:13:61
    Device MAC: 00:15:65:46:13:61
    Last Update: Mon Aug  6 16:55:53 2018
    Time to live: 180, Expires in: 140 Secs
    System capabilities : Bridge, Router, Phone
    Enabled capabilities: Bridge, Phone
    System name: IPPHONE
    System description:
    IP Phone
    Auto negotiation: Supported, Enabled
    Autoneg capability:
      10Base-T, HD: yes, FD: yes
      100Base-T, HD: yes, FD: yes
    Media attached unit type: 100BaseTXHD - 2 pair category 5 UTP, half duplex mode
    (15)
    LLDP-MED:
    Device Type:  Communication Device Endpoint (Class III)
    Capability:   LLDP-MED capabilities, Network policy, Extended power via MDI/PD,
    Inventory
    LLDP-MED Network Policy for: AppType: 1, Defined: no
      Descr:        Voice
      Layer 2 Priority: 0
      DSCP Value:   0
    Extended Power-over-Ethernet:
      Power Type & Source: PD Device
      Power Source: PSE
      Power Priority: high
      Power Value:  4000
    Inventory:
      Hardware Revision: 5.0.0.61
      Software Revision: 7.70.0.140
      Firmware Revision: 7.70.0.140
      Serial Number: 01565461361
      Manufacturer: Yealink
      Model:        SIP-T22P
    In the previous show command I have seen that LLDP-MED Network Policy is not defined, and the Layer 2 Priority and DSCP values are 0. I have seen other samples that respond that the LLDP-MED Network Policy is defined, and the Layer 2 Priority and DSCP values are the ones configured previously.
    Thanks for your help.
    Alejandro
