Network Management
  • 1.  PLC Cls and PLC Type
    Posted Nov 18, 2021 06:32 AM
    in latest firmware version of aruba switches there are 2 new voices in "sh power-over-ethernet brief" command:
    PoE Pwr Pwr Pre-std Alloc Alloc PSE Pwr PD Pwr PoE Port PLC PLC
    Port Enab Priority Detect Cfg Actual Rsrvd Draw Status Cls Type
    1 Yes low off usage usage 0.0 W 0.0 W Searching 0 -
    What are PLC Cls and PLC Type?
    Carabina5
  • 2.  RE: PLC Cls and PLC Type
    Posted Nov 18, 2021 08:35 AM
    PLC Type is the type (PoE Standard) of the connected device (list here) where standard PoE is type 1 (802.3af), PoE+ is type 2 (802.3at) and there are 3 and 4 for the 802.3bt 'PoE++' standard.
    The PLC Cls stands for PoE Class. From the 2920 Management and Configuration Guide:
    Your output shows a port that has PoE enabled, but the device is not powering (probably not a PoE device).
