Hello All,
I have a HPE 5140 24G PoE+ running 7.1.070, Release 6813 that was working perfectly and now the POE seems to be disabled and not able to enable it any more, giving the below response.
[TEL-GigabitEthernet1/0/2]poe enable
PSE or power source not ready. Check for loose DIMM connection or PSE firmware corruption and verify that the power source has been turned on.
[TEL]dis poe pse
PSE ID : 4
Slot No. : 1
SSlot No. : 0
PSE Model : LSP6POED
PSE Status : Enabled
PSE Fast Power Supply : Disabled
Power Priority : Low
Current Power : 0.0 W
Average Power : 0.0 W
Peak Power : 0.0 W
Max Power : 810.0 W
Remaining Guaranteed Power : 810.0 W
PSE CPLD Version : -
PSE Software Version : 147
PSE Hardware Version : 57633
PSE Legacy PD Detection : Disabled
Power Utilization Threshold : 80
PD Power Policy : Disabled
PD Disconnect-Detection Mode : AC
PSE ID : 7
Slot No. : 2
SSlot No. : 0
Peak Power : 0.0 W
Max Power : 810.0 W
[TEL]
Please advise if any solutions available.
Thanks and Regards
John
