Comware
  • 1.  Poe-power is not ready or communication failed! HPE V1910-24G-PoE (365W) JE007A
    Posted Dec 04, 2016 03:49 PM
    I've a problem with the PoE on the HPE V1910-24G-PoE (365W)  JE007A.
    When I connect a PoE ready device the switch doesn't supply the power.
    In Web Management Platform, PoE - PoE - PSE setup when I try to enable "Non-Standard PD Compatibility" I get error "Poe-power is not ready or communication failed!"
    CLI display poe pse the result is:
    it seams the PSE software is not installed.
    Any idea how to fix it?
    Thanks.
  • 2.  RE: Poe-power is not ready or communication failed! HPE V1910-24G-PoE (365W) JE007A
    Posted Dec 05, 2016 04:53 AM
    Detail: which software version (e.g. R1518 or R1518P01) is currently running your JE007?
    What is the output for display poe device command?
    If you power cycle the JE007 (by disconnecting the AC Power Supply cable - leaving it disconnected for just a minute - and then reconnect it) does the output of the display poe pse command you issued change or not?
    Yeah, it seems that the PoE PSE Firmware was faulty/damaged...indeed a normal display poe pse output would be similar to:
    <HP_JE007> display poe pse
     PSE ID                           : 4
     PSE Slot No                      : 1
     PSE SubSlot No                   : 0
     PSE Model                        : LSW124POED
     PSE Power Enabled                : enabled
     PSE Power Priority               : -
     PSE Current Power                : 0        W
     PSE Average Power                : 0        W
     PSE Peak Power                   : 0        W
     PSE Max Power                    : 170      W
     PSE Remaining Guaranteed         : 170      W
     PSE CPLD Version                 : -
     PSE Software Version             : 380
     PSE Hardware Version             : 57601
     PSE Legacy Detection             : disabled
     PSE Utilization-threshold        : 80
     PSE PD Disconnect Detect Mode    : AC
  • 3.  RE: Poe-power is not ready or communication failed! HPE V1910-24G-PoE (365W) JE007A
    Posted Dec 05, 2016 06:21 AM
    Detail:  Product Information HPE V1910-24G-PoE (365W), Switch Software Version Release 1518P01
    display poe device:
     PSE ID  SlotNo SubSNo PortNum  MaxPower(W)  State  Model
     1               1           0          24            740               off    LSW124POED
    after power cycle the JE007A the output is the same.
    <JE007A>display poe pse
     PSE ID                           : 1
     PSE Slot No                      : 1
     PSE SubSlot No                   : 0
     PSE Max Power                    : 740      W
     PSE Remaining Guaranteed         : 740      W
     PSE Software Version             : 0
     PSE Hardware Version             : 0
    Yes, probably The PSE software is damaged.
    Thanks for your help.
  • 4.  RE: Poe-power is not ready or communication failed! HPE V1910-24G-PoE (365W) JE007A
    Posted Dec 05, 2016 06:43 AM
    Yep, apart from not showing what is expected, that "740 Watt" value looks really irrealistic...probably contacting HPE Support would be actually the best path to start solving your issue (Especially not finding informations regarding how to re-set/re-flash - if that is an admitted operation separated from the normal Switch Firmware update - its PSE PoE Firmware...as is supported other HPE PoE Switch models).
