Comware
Poe-power is not ready or communication failed!
  • 1.  Poe-power is not ready or communication failed!
    Posted Jan 23, 2014 05:17 AM
    HP 7506 switch unable to enter poe enable pse pse-id, it is disabled by default, presented with Poe-power is not ready or communication failed!. Module is 48 port PoE.
    Does anyone know why this may be?
  • 2.  RE: Poe-power is not ready or communication failed!
    Posted Jan 24, 2014 04:44 AM
    hi qos
    Are the 2800W or 6000W PSU installed? Only these support PoE.
    br
    Manuel
