as pointed out before prioritizing shouldn't be needed if your network isn't overloaded. which on a general office network shouldn't be the case.
is there monitoring in place to view bandwidth usage of switch ports? do other traffic streams also suffer from issues? like can you download something from the internet at expected speed? can you ping within the network without loss?
if you connect a phone (or two to test) on the switch where the PBX / voice gateway is connected. does the bad quality occur there also?
do you have the possibility to just take one switch (either Aruba or other one) and for the test connect only the PBX and two phones? what is the result?
Original Message:
Sent: Feb 24, 2023 08:22 PM
Subject: poor voice vlan quality on Aruba switches
I contacted support, they got the logs and say they don't see any errors.
I do not know anymore. I don't know how to prioritize the voice vlan on an aos-cx switch.
i use thus dokument but not work
https://techhub.hpe.com/eginfolib/Aruba/OS-CX_10.04/5200-6711/index.html#book.html
is still the same poor quality
David
Original Message:
Sent: Feb 21, 2023 08:18 PM
i think you should plan this out properly, start with how are the voice traffic being marked and come up with the QoS calssification/marking plan then based on that ensure properly queuing isconfiured for end to end traffic.
Original Message:
Sent: Feb 21, 2023 12:41 PM
Popped into my mind that can this be caused by "checksum issue" in CX series?
Do you have any chance to capture data from phone interface with Wireshark and see if there is L3 checksum errors there in data packets?
Jori Luoto
Original Message:
Sent: Feb 17, 2023 09:11 AM
Especially in that case, please check all interfaces for errors/drops/etc... it may be a faulty cable, duplex mismatch or device configuration. With just a 'flat voice vlan', if you have poor audio also when it's not busy on the network, there likely is an issue with some link/port.
Original Message:
Sent: Feb 17, 2023 05:21 AM
Hello
PBX and Phones are in the voice vlan.
David
Original Message:
Sent: Feb 16, 2023 09:31 AM
QoS is mostly needed if there is a lack of bandwidth. If you find poor voice quality on most/all devices, I would check that all your interfaces (to the phones)/links (between the switches) are free of errors and are not overloaded.
You need to have quite some underdimensioning to get really poor audio quality; prioritizing traffic may help but in many networks voip is expected to work even without QoS; and many voip sessions these days run even over the internet where you have absolutely no control over QoS. Interface errors/flapping ports/duplex mismatches are more likely to cause what you are seeing.
Where is your PBX in this network?
Original Message:
Sent: Feb 14, 2023 03:11 AM
Hello Community,
we have Problem with Voice Vlan and we need Help
we swapped all our cisco switches with aruba and since then we have had poor voice vlan quality.
it hacks and sometimes breaks. We updated phone firmware, didn't help. We updated the switch firmware which didn't work either.
All phones are in voice vlan.
can someone help us is it possible to prioritize the voice vlan on Aruba?
what do we have to do to solve the problem? this is a new building and all network cables are new.
We didn't have that problem with the cisco switches, even though they were really old.
we have Aruab cx 6100, Aruab cx 6200, Aruab cx 6300.
regard David
David
