Wired Intelligent Edge
  • 1.  Port-access device-mode on AOS-S
    Posted May 07, 2025 10:36 AM
    Is there an equivalent to device-mode for AOS-S switches when using port-access security?
    When authenticating an Aruba AP, we want to authenticate only the first device (the AP), not the clients. The wireless system will obviously handle authentication for wireless clients, so we don't need/want the switches to do anything with them.
    On CX switches we would put these ports in auth-mode device-mode.     I have not been able to find the equivalent for AOS-S switches.
  • 2.  RE: Port-access device-mode on AOS-S
    Posted May 08, 2025 03:19 AM
    For AOS-S, you would use the HPE-Port-Dot1x-Port-Mode (for 802.1X authentication of your AP):
    Or HPE-Port-MACPort-Mode in case of MAC authenticaiton of your AP:
    I prefer returning Named VLANs, where if you prepend them with '2' they are untagged (example: Untrusted VLAN), with '1' prepended they are tagged (example: Voice VLAN). With VLAN ID you would need to do all kinds of math to get to the numeric VLAN ID so Named VLANs are much simpler.
  • 3.  RE: Port-access device-mode on AOS-S
    Posted May 09, 2025 02:49 AM
    Please be aware that the attributes vary depending on the authentication method:
    802.1x
    Radius:Hewlett-Packard-Enterprise HPE-Port-Dot1x-Port-Mode=Port-Based (1)
    Radius:Hewlett-Packard-Enterprise HPE-Port-Macauth-Client-Limit=0
    MAC-Auth
    Radius:Hewlett-Packard-Enterprise HPE-Port-MA-Port-Mode=Port-Based (1)
    Radius:Hewlett-Packard-Enterprise HPE-Port-Dot1x-Client-Limit=0
    Greez,
    Uli
