Comware
  • 1.  Port-access mac-based Problem
    Posted Nov 19, 2008 12:37 PM
    I'm configuring several 2626 (H.10.45) and 5308xl (E.11.03)switches for mac-based authentication and would be very happy about some hints :)
    Scenario:
    Multiple thinclients and printers should be authenticated via MAC.
    There are several clients and printers on each switch.
    Problem:
    Thinclients work, Printers don't (mostly HP LJ 1000 - 4000 Series). There's one exception: a
    Samsung ML-2550, altough the same model on a differnt switch doesn't work, haven't found any differences yet. As long as a MAC is supplied the client shouldn't matter, or I'm wrong?
    Activated Ports with printers connected are shown under *show port-access mac-based* but both "Authenticated Clients" and "Unauthenticated Clients" are 0. Thinclients have "Authenticated Clients" 1.
    I have no clue why :(
    There are no authentication attempts on IAS-Servers (MS IAS), thinclients are sucessfully logged. Apparently the switches don't send requests for printers.
    Summary:
    MAC-based authentication works for thinclients, not for printers on the same switch.
    Thinclients authenticate sucessfully.
    Printers go immediatly offline if authentication is actived - with no requests to IAS send.
    Both use the same IAS-policies.
    My only hints so far are:
    Logging:
    "18:02:44 ports: port H1 is Blocked by AAA"
    "18:02:47 ports: port H1 is Blocked by STP"
    show port-acces mac-based:
    Port Access MAC-Based Status
    Authenticated Unauthenticated Current RADIUS ACL
    Port Clients Clients VLAN ID Applied?
    H1 0 0 1 No
    I've read this guide, but it hasn't given me any pointers:
    http://cdn.procurve.com/training/Manuals/2900-ASG-Jan08-3-WebMacAuth.pdf
    Hopefully somebody has experience with this behavior :)
    Kind regards,
    Gernot
  • 2.  RE: Port-access mac-based Problem
    Posted Nov 20, 2008 05:15 AM
    Hi Gernot,
    <QUOTE>
    <UNQUOTE>
    What do you mean? are the printer offline as seen from a printeserver? or does the printer itself goes offline?
    Are the printers setup as DHCP or static adress?
    <QUOTE>
    <UNQUOTE>
    in dhcp-requests there can be a "vendor-specific" field (option 43?). wich can result in different handling of the request.
    maybe the output from
    show port-access mac-based config
    and
    show port-access mac-based clients
    instead of the current status will help.</UNQUOTE></QUOTE></UNQUOTE></QUOTE>
  • 3.  RE: Port-access mac-based Problem
    Posted Nov 20, 2008 06:08 AM
    Hello Pieter,
    thank you for your reply.
    Output *show port-access mac-based config*:
    Port Access MAC-Based Configuration
    MAC Address Format : no-delimiter
    Allow RADIUS-assigned dynamic (GVRP) VLANs [No] : No
    Client Client Logoff Re-Auth Unauth Auth Cntrl
    Port Enabled Limit Moves Period Period VLAN ID VLAN ID Dir
    H1 Yes 1 No 300 0 0 0 both
    Output *show port-access mac-based clients*:
    Port Access MAC-Based Client Status
    Port MAC Address Session Status Time
    Yes, it's empty, working clients are shown properly:
    24 0000f0-a345fd authenticated 67,211
    Printers are immediatly not reachable per ping. And port is displayed as closed.
    Clients have static IPs, no DHCP-Voodoo :)
    Kind Regards,
    Gernot
  • 4.  RE: Port-access mac-based Problem
    Posted Nov 24, 2008 03:50 AM
    Has nobody an idea?
  • 5.  RE: Port-access mac-based Problem
    Posted Dec 01, 2008 01:48 PM
    Still nobody?
  • 6.  RE: Port-access mac-based Problem
    Posted Dec 02, 2008 06:42 AM
    There is a controlled directions feature for aaa, try changing that to 'in'. (That way an unauthenticated client will still receive broadcast/multicast traffic from the network which is what the printer might need to see before it sends any return traffic to kick off the mac-auth process).
    Also, make sure you update to the latest version firmware.
  • 7.  RE: Port-access mac-based Problem
    Posted Dec 09, 2008 02:42 AM
    Hello Matt,
    i've tried in, out and both, nothing worked. All working clients (Thinclients) have both configured.
    Firmware is 10.45 for 2626 and 11.03 for 5308.
    Kind regards,
    Gernot
  • 8.  RE: Port-access mac-based Problem
    Posted Dec 09, 2008 03:30 PM
    H.10.45 is not the latest software, you should rather try H.10.74
  • 9.  RE: Port-access mac-based Problem
    Posted Dec 10, 2008 05:38 PM
    I have been working over the last week to keep my jetdirects authenticated with MAC based auth all the time, and I have been quite sucessful with the following.
    Upgraded all jetdirects to their latest firmware, DOWNgraded any jetdirect J7949E on firmware v33.15 to v33.14 (.15 is horribly broken and crashes after a couple of minutes usually).
    I have enabled SLP protocol on all the print servers, I have then telneted into the jetdirect to set slp-keep-alive (available with the firmware updates) to a value of 2 (2 minutes between slp anouncments).
    I have changed the MAC age time on all the switches to 900 seconds from the default 300.
    Jetdirects now announce themselves every 2 minutes stopping the switch forgetting that they exist. I have added a logoff-period of 1800 seconds to a single port with a Xerox printer on it which stops it reauthenticating every 10 minutes (unable to change slp interval on it).
    This may or may not help, but I've had the printers on line for the last week now and when I ping, they are still there!
  • 10.  RE: Port-access mac-based Problem
    Posted Dec 17, 2008 09:08 AM
    Thank you for your input.
    I have upgraded my Firmware, but still same behavior.
    @DMCCoy: excellent tips :)
    Time out problems would be cool, at least I would be one step further...
