Original Message:
Sent: Jul 06, 2023 12:04 PM
Subject: Port-Based Authentication with radius
Hello Waldemar
I found what it was missing looking at your example.
I missed the following
aaa port-access mac-based 2/G8
before this
aaa port-access mac-based 2/G8 unauth-vid 203
thanks a lot for your help
appreciated
SC
Original Message:
Sent: Jul 06, 2023 11:45 AM
You have authentication set up, but not yet enabled.
It must look like this:
interface 2
no power-over-ethernet
untagged vlan 1
aaa port-access authenticator
aaa port-access authenticator tx-period 15
aaa port-access authenticator supplicant-timeout 15
aaa port-access authenticator max-eap-retries 1
aaa port-access authenticator client-limit 2
aaa port-access mac-based addr-limit 2
aaa port-access mac-based unauth-vid 500
aaa port-access controlled-direction in
aaa port-access auth-order authenticator mac-based
aaa port-access auth-priority authenticator mac-based
exit
sh port-access config
Port Access Status Summary
Port-access authenticator activated [No] : Yes
Allow RADIUS-assigned dynamic (GVRP) VLANs [No] : No
Use LLDP data to authenticate [No] : No
Dot1X EAP Identifier Compliance [Disabled] : Disabled
Allow incremental EAP identifier only [Disabled] : Disabled
802.1X 802.1X Web Mac LMA Cntrl Mixed Speed
Port Supp Auth Auth Auth Auth Dir Mode VSA MBV
1 No No No No No in No No Yes
2 No Yes No Yes No in No No Yes
Use the following commands to enable authentication:
aaa port-access authenticator active - global command, activates authentication in general
aaa port-access authenticator 2 - enables 802.1X authentication for port 2
aaa port-access mac-based 2 - enables MAC address authentication for port 2
Waldemar
ACCX # 1377, ACEP, ACA - Network Security
Original Message:
Sent: Jul 06, 2023 10:59 AM
Hello
I also tried this configuration
interface 2/G8
untagged vlan 4000
aaa port-access mac-based unauth-vid 203
exit
but it still doesn't make any authentication request to the radius
Original Message:
Sent: Jul 06, 2023 09:41 AM
But that's the point: if the external PC doesn't do 802.1X port authentication, it can't fail. The switch is waiting for credentials via EAPOL on the port, and the external PC is not sending.
Waldemar
Original Message:
Sent: Jul 06, 2023 07:46 AM
the port is configured exactly the same as the one for the PC on the domain.
Obviously the goal is to have all the ports with the same base configuration and applying settings based on the device attached.
So we cannot "manage" the external computers and we thought to treat them as "failed authentication".
The port I'm using now for the test is configured as below
sh run int 2/g8
Running configuration:
interface 2/G8
untagged vlan 4000
aaa port-access authenticator unauth-vid 4000
exit
Original Message:
Sent: Jul 06, 2023 06:16 AM
does the "external" computer also do 802.1X authentication? Does it have port authentication enabled? If not - then it will not make any 802.1X authentication request, in this case you have to configure fallback to MAC address authentication in the switch. The "unauth-vid 4000" must be removed from the command "aaa port-access authenticator 2/G7-2/G8 unauth-vid 4000". You must add the "aaa port-access mac-based 2/G7-2/G8 unauth-vid 4000" command.
Waldemar
Original Message:
Sent: Jul 06, 2023 04:37 AM
Hello
as per the DHCP "stuff" we solved, it was a false problem, due to a different problem.
It's still to solve why the "external" computer attached to the port doesn't "fail" authentication.
We don't even see any authentication request on Radius Server's log
It's just seen as guest as reported before
Original Message:
Sent: Jul 06, 2023 04:28 AM
I would run a packet capture on the port from a non-corporate machine. From there you might find out what traffic you see, and who/what device is responding to the DHCP request. At the same time, check on your switch in which VLAN the mac address for your client resides and where the mac address lives that responded to your DHCP request.
Original Message:
Sent: Jul 05, 2023 11:52 AM
we're trying to configure port-based authentication with radius server to enable VLAN assignment based on Users/Computer membership for company users and externals.
So we configured some ports to test the connection with a domain joined computer ( with certificates ) and non-domain joined computer ( as external device )
The Domain joined computer works as expected and it goes through 802.11 Cert authentication by the radius server and gets its assigned VLAN.
The "external" computer instead doesn't even "fail" the authentication and is seen as "guest"
# sh port-access authenticator 2/g8
Port Access Authenticator Status
Auths/ Unauth Untagged Tagged % In RADIUS Cntrl
Port Guests Clients VLAN VLANs Port COS Limit ACL Dir Port Mode
2/G8 0/1 0 4000 No No No No both 1000FDx
We expected that a device that is not able to authenticate via Radius would "fail" the authentication and be put in the Unauth-vid as per the configuration
The port is configured as follows
interface 2/G8
untagged vlan 4000
exit
the VLAN 4000 is a "dead" vlan in the sense that no service runs on it but "strangely" the external computer is able to acquire a DHCP IP address from VLAN 201
What we're missing ?
thanks
