Wired Intelligent Edge
Port blocked by LACP and virtual lan disabled
This thread has been viewed 19 times
  • 1.  Port blocked by LACP and virtual lan disabled
    Posted Sep 06, 2022 03:54 AM
    I found something in another post and have not been able to locate it again, but recently I have a switch that started to give me the following errors in the log:
    I 09/04/22 03:31:07 00077 ports: port 15 in Trk1 is now off-line
    I 09/04/22 03:31:05 00435 ports: port 15 is Blocked by LACP
    I 09/04/22 03:31:04 00077 ports: port 15 in Trk1 is now off-line
    I 09/04/22 03:31:04 00079 ports: trunk Trk1 is now inactive
    I 09/04/22 03:30:36 00001 vlan: Telco <--> swtTagShack1 virtual LAN enabled
    I 09/04/22 03:30:36 00076 ports: port 15 in Trk1 is now on-line
    I 09/04/22 03:30:36 00078 ports: trunk Trk1 is now active
    I 09/04/22 03:30:33 00435 ports: port 15 is Blocked by LACP
    I 09/04/22 03:30:33 00002 vlan: Telco <--> swtTagShack1 virtual LAN disabled
    I 09/04/22 03:30:33 00077 ports: port 15 in Trk1 is now off-line
    I 09/04/22 03:30:33 00079 ports: trunk Trk1 is now inactive
    W 09/04/22 02:25:15 00329 FFI: port 15-Excessive CRC/alignment errors. See help.
    I 09/04/22 01:40:22 00001 vlan: Telco <--> swtTagShack1 virtual LAN enabled (4 times in 60 seconds)
    I 09/04/22 01:40:22 00076 ports: port 15 in Trk1 is now on-line
    I 09/04/22 01:40:22 00078 ports: trunk Trk1 is now active
    I 09/04/22 01:40:20 00435 ports: port 15 is Blocked by LACP
    I 09/04/22 01:40:19 00077 ports: port 15 in Trk1 is now off-line
    I 09/04/22 01:40:18 00435 ports: port 15 is Blocked by LACP
    I 09/04/22 01:39:49 00002 vlan: Telco <--> swtTagShack1 virtual LAN disabled (4 times in 60 seconds)
    I 09/04/22 01:39:49 00077 ports: port 15 in Trk1 is now off-line
    I 09/04/22 01:39:49 00079 ports: trunk Trk1 is now inactive
    W 09/04/22 01:39:47 00329 FFI: port 15-Excessive CRC/alignment errors. See help.
    At first I thought it was something with the patch cables or transceivers, but I did replace them both on both sides of the connection and I still see the log messages. IT isn't stopping anything and I don't think anyone has noticed it yet, but I am having some trouble narrowing it down. It just started and we have not had any issues for the last 2 years with this connection. There have not been any changes made either.
    Port 15 is setup as an LACP trunk (trunk 15 trk1 lacp). I do see at the end of sho run this: spanning-tree Trk1 priority 4. I was thinking that might be what is causing my problem, but I am not sure and like I said, there have been no modifications to this connection or the switch...
    rford1219
  • 2.  RE: Port blocked by LACP and virtual lan disabled
    Posted Sep 06, 2022 04:48 AM
    Blocked by LACP suggests to me that the other side is not sending LACP packets.
    Do you have more ports than port 15 on your Trk1?
    For completeness, a Trunk in ArubaOS Switch is what in some other switches is called a portchannel or etherchannel, it's bundling multiple physical links to a single logical link for increased capacity or link redundancy. Having a trunk with a single interface doesn't make sense in most cases.
