Government and Military
Possible Juniper LLDP issue
  • 1.  Possible Juniper LLDP issue
    Posted Feb 16, 2017 06:13 PM
    Hello all,
    I am having issues with powering 270 series APs via Juniper SRX220H-POE (SRX220) device(s). I am working with a particular gov't unit as an integrator, so I do not have direct access to the Juniper device(s). There are currently two 7010 controllers running VRRP for redundancy, two AP-274-F1s, and two AP-277-F1s plugged into one SRX220H-POE.The four APs acting as Mesh Portals can be seen by the controller, but no Mesh Points can be seen. In working with the gov't POC, LLDP has been enabled on the SRX and Class 4/max power has been set on the four ports that have APs connected to them. Below is the output I get from the master controller while troubleshooting the issue.
    (***** Master) #show ap debug system-status ap-name B********_Mesh_Portal | begin Power
    Power Status
    Operational State          POE-AF: Ethernet port 1 disabled; All radios disabled;
    Current HW State           POE-AF: Ethernet port 1 disabled; All radios disabled;
    LLDP Negotiated POE Power  0.0W
    Bandwidth Contracts Information
    Received BWM Config:
            ACL                                                            DIR  Contract-ID PerUser UseCount Rate
    Allocated Contracts:
    Contract-ID Rate       UseCount Available-Bytes Max-Bytes Policed-Bytes
    System Status Script
    aruba_dbg_system_status Start time: Thu Feb 16 15:48:59 PST 2017
    ====== netstat -nla ======
    Active Internet connections (servers and established)
    Proto Recv-Q Send-Q Local Address           Foreign Address         State
    udp        0      0 127.0.0.1:19999         0.0.0.0:*
    udp        0      0 0.0.0.0:54838           0.0.0.0:*
    udp        0      0 0.0.0.0:1144            0.0.0.0:*
    udp        0      0 :::8209                 :::*
    udp        0      0 :::8211                 :::*
    udp        0      0 :::546                  :::*
    raw        0      0 :::58                   :::*                    0
    Active UNIX domain sockets (servers and established)
    Proto RefCnt Flags       Type       State         I-Node Path
    unix  2      [ ]         DGRAM                    1299   /tmp/.sock/8223.sock
    unix  2      [ ]         DGRAM                    1301   /tmp/.sock/9223.sock
    unix  2      [ ]         DGRAM                    1318   /tmp/.sock/8451.sock
    unix  2      [ ]         DGRAM                    1320   /tmp/.sock/9451.sock
    unix  2      [ ]         DGRAM                    1322   /tmp/.sock/8452.sock
    unix  2      [ ]         DGRAM                    1324   /tmp/.sock/9452.sock
    unix  2      [ ]         DGRAM                    1457   /tmp/.sock/8225.sock
    unix  2      [ ]         DGRAM                    1459   /tmp/.sock/9225.sock
    unix  2      [ ]         DGRAM                    1480   /tmp/.sock/8433.sock
    unix  2      [ ]         DGRAM                    1482   /tmp/.sock/9433.sock
    unix  2      [ ]         DGRAM                    1229   /tmp/.sock/8370.sock
    unix  2      [ ]         DGRAM                    1487   /tmp/.sock/15208.sock
    unix  2      [ ]         DGRAM                    1231   /tmp/.sock/9370.sock
    unix  2      [ ]         DGRAM                    1489   /tmp/.sock/16208.sock
    unix  2      [ ]         DGRAM                    1234   /tmp/msghdlr_comm
    unix  2      [ ]         DGRAM                    1493   /tmp/meshd_hostapd_sync
    unix  2      [ ]         DGRAM                    1238   /tmp/.sock/8210.sock
    unix  4      [ ]         DGRAM                    1241   /dev/log
    unix  2      [ ]         DGRAM                    1513   /tmp/.sock/8410.sock
    unix  2      [ ]         DGRAM                    1515   /tmp/.sock/9410.sock
    unix  2      [ ]         DGRAM                    1611
    unix  2      [ ]         DGRAM                    1509
    unix  2      [ ]         STREAM                   1002
    unix  3      [ ]         STREAM     CONNECTED     996
    unix  3      [ ]         STREAM     CONNECTED     995
    /proc/net/softnet_stat:
    00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    00001f2d 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    cat  /proc/net/anul_ap_stats
    ANUL AP stats
    TX-txnid:0
    RX-txnid:0
    TX-Tot:0
    RX-Tot:0
    RX-Err:0
    RX-Throttle:0
    Non-80211:0
    Mgmt-tot:0
    CTL:0
    Data:0
    Other:0
    Mgmt-err:0
    Mgmt-subtypes:
    aruba_dbg_system_status Finished time: Thu Feb 16 15:48:59 PST 2017
    aruba_dbg_system_status: Read 3201 bytes in 61 lines. Truncated:FALSE
    As a possible fix, I enabled LLDP on the controller uplink port as well, but the SRX is inline between the controller and APs.
    (***** Master) # show lldp interface gigabitethernet 0/0/0
    Interface: GE0/0/0
    LLDP Tx: Enabled, LLDP Rx: Enabled
    Proprietary Neighbor Discovery: Disabled
    LLDP-MED: Disabled
    Fast Transmit interval: 1, Fast Transmit message counter: 4
    Transmit interval: 30, Transmit hold 4, Hold timer: 120
    (***** Master) # show lldp statistics ?
    interface               Interface
    |                       Output Modifiers
    (***** Master) # show lldp statistics interface gigabitethernet 0/0/0
    LLDP Statistics
    Interface  Received  Unknown TLVs  Malformed  Transmitted
    GE0/0/0    0         0             0          79
     (***** Master) # show lldp neighbor interface gigabitethernet 0/0/0
    Capability codes: (R)Router, (B)Bridge, (A)Access Point, (P)Phone, (S)Station
                      (r)Repeater, (O)Other
    LLDP Neighbor Information
    Local Intf  Chassis ID  Capability  Remote Intf  Expiry (Secs)  System Name
    Number of neighbors: 0
  • 2.  RE: Possible Juniper LLDP issue
    Posted Feb 16, 2017 06:35 PM
    What version of ArubaOS is this?
  • 3.  RE: Possible Juniper LLDP issue
    Posted Feb 16, 2017 06:49 PM
    6.4.4.10
  • 4.  RE: Possible Juniper LLDP issue
    Posted Feb 16, 2017 07:33 PM
    By adding an inline PoE+ power injector between the SRX and AP, the AP comes up with the following:
    (***** Master) #show ap debug system-status ap-name B385-TS3A_Mesh_Portal | begin Power
    Power Status
    Operational State          POE-AT: No restrictions
    Current HW State           POE-AT: No restrictions
    Unfortunately, using inine power injectors throughout this solution is not feasible. I've simply done so for testing.
