  • 1.  Posture assessment
    Posted Oct 22, 2018 06:06 PM
    Hello ,
    we are a large organisation and we want to enable posture assessment like AV check , Registry checks etc on all our wired/wireless endpoints . As of now we are using native dot1x agent and no client software is installed on any end point ,
    Is Aruba Onguard mandatory for Posture assessment (if we wont go for NAP agent) ,  Cant we do posture with Native client ?
  • 2.  RE: Posture assessment
    Posted Oct 22, 2018 06:13 PM
    Hi, based on the number of questions recently, I’d recommend you work with your Aruba ClearPass partner on a full design.
    To directly answer your question, OnGuard is used for traditional posture assessment.
  • 3.  RE: Posture assessment
    Posted Oct 22, 2018 06:44 PM
    Ok .thanks . I know I am putting lot of queries and will work with partner . But does posture work for native supplicant
  • 4.  RE: Posture assessment
    Posted Oct 22, 2018 06:51 PM
    Network supplicants do not provide posture data.
