Hello all,
In a temporary building I need to power 230 access points which use 15W (or 30W PoE when the access point itself powers another device). We use our standard Aruba 5406R-zl2 switches to provide the location with network connectivity. We only use the following two module types in our switches:
- Aruba 20-port 10/100/1000BASE-T PoE+/4-port 1G/10GbE SFP+ MACsec v3 zl2 Module (J9990A)
- Aruba 24-port 10/100/1000BASE-T PoE+ MACsec v3 zl2 Module (J9986A)
While I know there is a maximum power budget available depending on the power supply used, my question is:
What is the maximum power capacity per module? I cannot find anything in documentation (
HP Switch v3 zl2 Modules Installation Guide). Everything I find says
"each port can deliver 30W power for PoE", but if I calculate 24 ports x 30W then I get 720 Watt / module (which sounds like a lot of power for one module to handle).
When I look on random production switches I get various "Maximum Power" results. Sometimes I see numbers as low as 388 Watt, sometimes 633 Watt. In the example below the same module is seated in slot A and slot F, but slot F has a couple of access points connected while slot A has not.
switchA# show power-over-ethernet slot a
Status and Counters - System Power Status for slot A
Maximum Power : 523 W Operational Status : On
PSE Power Reserved : 0 W Usage Threshold (%) : 80
PD Power Draw : 0 W +/- 6 W
switchA# show power-over-ethernet slot f
Status and Counters - System Power Status for slot F
Maximum Power : 633 W Operational Status : On
PSE Power Reserved : 104 W Usage Threshold (%) : 80
PD Power Draw : 95 W +/- 6 W
So can a single module actually handle 720 Watt of power if it needs to? Meaning: I can actually connect 24 access points that draw 30W on one module? Or is there a maximum per module, and I will have to spread the access points over multiple modules.
Thanks in advance!
Kind regards,
Niels Mejan
University of Twente
(P.S. The question is for the purpose of getting the answer. I will be spreading the access points over various switches and modules anyway so I can make the cabling of the switch look nice too. This is a
"patch once, don't touch it" situation for ~7 years with 115 access points per rack. Since we use 1100 Watt PSU's that have 900 Watt for PoE available each rack will have 2 switches, and each switch has 4 modules, so in the end it is ~15 access points per module.)
Niels Mejan
