I have been working for several months on a Powershell module that uses the Aruba Central REST API.
This module is available on psgallery(.com) : PowerArubaCL 0.1.0
Powershellgallery |
remove preview |
PowerArubaCL 0.1.0 |
Copy and Paste the following command to install this package using PowerShellGet More Info You can deploy this package directly to Azure Automation. Note that deploying packages with dependencies will deploy all the dependencies to Azure Automation. Learn More Deploy to Azure Automation Manually download the .nupkg file to your system's default download location. |
View this on Powershellgallery > |
Actually, we support to connect to HTTPS using API
and configure the following feature :
- Devices (Inventory): Get
it is very easy to use (and install)
Launch powershell command line and launch following command for install
Install-Module PowerArubaCL
for load the module
Import-Module PowerArubaCL
Connect to your Aruba Central Account
Connect-ArubaCL -Region EU-1 -client_id XXXX -client_secret XXXX -customer_id XXX
it will be ask the credential
for example to get all Devices (Inventory) type IAP
Get-ArubaCLInventoryDevices -type IAP
You can get the list of command available via
Get-Command -Module PowerArubaCL
and for get help (and example about a command for example Get-ArubaCLInventoryDevices)
Get-Help Get-ArubaCLInventoryDevices -Full
More documentation, example is available on https://github.com/PowerAruba/PowerArubaCL and you can also report issue/enhance !
PowerArubaCL: Powershell Module to use Aruba Central
ACEP / ACMX #107 / ACDX #1281
