  • 1.  PowerArubaCP : a powershell module for use ClearPass REST API
    Posted Mar 03, 2019 08:44 AM
    I have been working for several months on a Powershell module that uses the ClearPass REST API.
    This module is available on psgallery(.com) : https://www.powershellgallery.com/packages/PowerArubaCP/
    Actually, we support to connect to HTTPS using Token API
    and configure the following feature :
    •  NetworkDevice (NAS) : Add / Get / Set /Remove
    it is very easy to use (and install)
    Launch powershell command line and laucnh following command for install
    Install-Module PowerArubaCP
    for load the module
    Import-Module PowerArubaCP
    Connect to your ClearPass
    Connect-ArubaCP 192.0.2.1 -token aaaaaaaaaaaaaaaaaaaaa
    for example to get all Network Device (Nas)
    Get-ArubaCPNetworkDevice
    You can get the list of command available via
    Get-Command -Module PowerArubaCP
     and for get help (and example about a command for example Add-ArubaCPNetworkDevice)
    Get-Help Add-ArubaCPNetworkDevice -Full
    More documentation, example is available on https://github.com/PowerAruba/PowerArubaCP and you can also report issue/enhance !
  • 2.  RE: PowerArubaCP : a powershell module for use ClearPass REST API
    Posted Apr 08, 2019 05:08 PM
    Thank you so much for creating this. I think it will be quite useful.
    A question about syntax. I am trying to set a password for a local user account and no matter what I do, I can't seem to get the syntax correct. I am trying:
    Invoke-ArubaCPRestMethod -method "patch" -uri "api/local-user/3001" -body "{'password': 'NewPass123'}"
    But PS always returns:
    WARNING: The ClearPass API sends an error message:
    WARNING: Error description (code): Internal Server Error (500)
    WARNING: Error details: {"type":"http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html","title":"Internal Server
    Error","status":500,"detail":"Data provided to create must be either an array or object; received \"string\""}
    Unable to use ClearPass API
    At C:\Windows\system32\WindowsPowerShell\v1.0\Modules\PowerArubaCP\Private\RestMethod.ps1:64 char:13
    + throw "Unable to use ClearPass API"
    + CategoryInfo : OperationStopped: (Unable to use ClearPass API:String) [], RuntimeException
    + FullyQualifiedErrorId : Unable to use ClearPass API
    From the error, it would appear that the API is expecting an array in the body, but I've tried specifying multiple parameters in comma delimited format but still get the same error. Any help would be appreciated.
    Thanks!
  • 3.  RE: PowerArubaCP : a powershell module for use ClearPass REST API
    Posted Apr 09, 2019 01:30 AM
    Thanks!
    Can you open a issue on PowerArubaCP Github ? Better place for this
  • 4.  RE: PowerArubaCP : a powershell module for use ClearPass REST API
    Posted Oct 14, 2019 03:24 PM
    a new release is available... 0.3.0 !
    What new ?
    • Support of PowerShell (Core) 6 (tested on Linux/Ubuntu and macOS) (#15)
    • Add Pester integration test (#17, #21)
    • Support of limit parameter fix #14 (#16) (But limited to 1000...)
    • Add Set-ArubaCPNetworkDevice and add better filtering to Get-ArubaCPNetworkDevice (#21)
    • Add GitHub Actions for launch Script Analyzer (#19, #22, #23) and publish release (#26)
    Tested on ClearPass 6.7.2 and 6.8.2 :
    • Windows 10 with Powershell 6.2.3
    • Windows 10 with Powershell 5
    • macOS with Powershell 6.2.3
    • Ubuntu 18.04 with PowerShell 6.2.3
    Update-Module PowerArubaCP
    See also https://github.com/PowerAruba/PowerArubaCP/releases/tag/v0.3.0
  • 5.  RE: PowerArubaCP : a powershell module for use ClearPass REST API
    Posted Jan 28, 2020 04:08 PM
    a new release is availabe => 0.4.0
    What new
    • Static Host List (Add/Get/Set/Remove and also Add/Remove Members) (#30)
    • Application License (Add/Get/Remove) (#31)
    • Platform (Get CPPM Version and Server Version/Configuration) (#32)
    • Multi Connection (#33)
    • Add port parameter to connection (#34)
    • Service (Get and Enable/disable) (#36)
    • Endpoint (Add/Get/Remove) (#38)
    • New connection method (using oauth client_id/client_secret) (#39)
    Tested on ClearPass 6.7.2 and 6.8.4 :
    For update like always =>
    Update-module PowerArubaCP
  • 6.  RE: PowerArubaCP : a powershell module for use ClearPass REST API
    Posted Jun 11, 2021 04:44 AM
    I'm proud to announce a new release of PowerArubaCP ! 0.5.0
    What new ?
    • Fix support of ClearPass 6.9.x (about hyperlen for MAC Address on Static Host List...) (#46)
    • Add support of Pester v5 (#48)
    • Update support of PSSA (#47 #49)
    • Fix use of ShouldProcess (Break Compability : noconfirm -> confirm:$false) (#50)
    • Add PowerArubaCP Logo (#54)
    • Update documentation (Add example for Static Host List...) (#59)
    • Add Network Device Group (#55)
    • Add Deploy and Configure ClearPass VM (for initial setup) (#51)
    • Add DeviceFingerprint (Get and Add) (#53)
    • Add Get Auth Method and Source (#56)
    • Fix CPPM 6.10.x support (#58)
    Tested on ClearPass 6.8.9, 6.9.6 and 6.10.0 :
    • Windows 10 with PowerShell 7.1.3
    • Windows 10 with PowerShell 5
    • macOS with PowerShell 7.1.3
    • Ubuntu 20.04 with PowerShell 7.1.3
    For install
    Install-Module PowerArubaCP​
    or for upgrade
    ACEP / ACMX #107 / ACDX #1281
  • 7.  RE: PowerArubaCP : a powershell module for use ClearPass REST API
    Posted Jan 31, 2024 05:01 AM
    a new release is available : PowerArubaCP 0.7.0
    with the following changelog
    What's Changed
    New Contributors
    Tested on ClearPass 6.10.8, 6.11.7, 6.12.0 :
    • Windows 10 with PowerShell 7.4.1
    • macOS with PowerShell 7.4.1
    • Ubuntu 22.04 with PowerShell 7.4.1
    PowerArubaCL: Powershell Module to use Aruba Central
