Wired Intelligent Edge
PowerArubaCX : a powershell module for use ArubaCX REST API
  • 1.  PowerArubaCX : a powershell module for use ArubaCX REST API
    Posted Apr 15, 2019 03:14 PM
    I have been working for several months on a Powershell module that uses the ArubaCX REST API.
    This module is available on psgallery(.com) : https://www.powershellgallery.com/packages/PowerArubaCX/
    Actually, we support to connect to HTTPS using login/passwrd
    and get the following feature :
    • System
    • Interfaces
    • Vlans
    • LLDP Neighbor
    it is very easy to use (and install)
    Launch powershell command line and launch following command for install
    Install-Module PowerArubaCX
    for load the module
    Import-Module PowerArubaCX
    Connect to your Aruba CX
    Connect-ArubaCX 192.0.2.1
    You need to use -SkipCertificateCheck if the certificate is not valid
    for example to get system info
    Get-ArubaCXSystem
    Like the API, it is possible to select what need to display (configuration, status, statistics) using -selector parameter
    for example to get system info statistics
    Get-ArubaCXSystem -selector statistics
    You can also select what you want to display using -attributes parameter
    For example to display hostname and dns servers of system
    Get-ArubaCXSystem -attributes hostname,dns_servers
    for Interfaces, it is also possible to choice the depth (from 0 to 3)
    Get-ArubaCXInterfaces -depth 1
    You can get the list of command available via
    Get-Command -Module PowerArubaCX
     and for get help (and example about a command for example ArubaCXLLDPNeighbor)
    Get-Help Get-ArubaCXLLDPNeighbor -Full
    It is already compatible with PowerShell 6 (Core) and macOS/Linux !
    More documentation, example is available on https://github.com/PowerAruba/PowerArubaCX and you can also report issue/enhance !
  • 2.  RE: PowerArubaCX : a powershell module for use ArubaCX REST API
    Posted Mar 06, 2020 01:40 AM
    PoweArubaCX 0.4.x is available !
    What new :
    • Add compatibility with 10.04 (#21, #27 )
    • Add vsx_peer parameter for all cmdlets (#22)
    • Multi Connection and add port parameter to connection (#26)
    • Add Tests (Pester) (#31)
    • Add User and firmware get cmdlets (#32)
    • Vlans : Add/Get/Set/Remove Cmdlets (#33)
    • Interfaces : Set and Add/Remove VlansTrunks (#34)
    • System : Set system cmdlet (#35)
    Remove Get-ArubaCXPorts (API not longer with 10.04)
    Tested on 6300, 8320, OVA with release 10.04.00430
    • Windows 10 with Powershell 6.2.4
    • macOS with Powershell 6.2.4
  • 3.  RE: PowerArubaCX : a powershell module for use ArubaCX REST API
    Posted Feb 15, 2022 04:39 AM
    PoweArubaCX 0.5.0 is available !
    What's Changed
    Tested on 6300, 8320, OVA with release 10.06, 10.07, 10.08, 10.09
    • Windows 10 with Powershell 5 / 7.2.1
    • macOS with Powershell 7.2.1
    • Linux with PowerShell 7.2.1
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
