Wired Intelligent Edge
PowerArubaSW : a powershell module for use ArubaOS Switch REST API
This thread has been viewed 118 times
  • 1.  PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Sep 11, 2018 05:32 AM
    I have been working for several months on a Powershell module that uses the ArubaOS Switch REST API.
    This module is available on psgallery(.com) : https://www.powershellgallery.com/packages/PowerArubaSW/
    Actually, we support to connect to HTTPS or HTTP
    and configure the following feature :
    •  Vlans
    •  Vlans-Ports (affect a vlan tagged/untagged/forbidden to a port/interface)
    • Rest info (get api-version, timeout...)
    • LLDP
    • LACP
    • Led Locator
    it is very easy to use (and install)
    Launch powershell command line and launch following command for install
    Install-Module PowerArubaSW
    for load the module
    Import-Module PowerArubaSW
    Connect to your switch
    Connect-ArubaSW 192.0.2.1
    You get a prompt to ask credential
    Need to have enable web-managemnt ssl and a user/password
    for example to get all vlan use
    Get-ArubaSWVlan
    You can get the list of command available via
    Get-Command -Module PowerArubaSW
     and for get help (and example about a command for example Get-ArubaSWVlans)
    Get-Help Get-ArubaSWVlans -Full
    More documentation, example is available on https://github.com/PowerAruba/PowerArubaSW and you can also report issue/enhance !
  • 2.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Sep 20, 2018 12:19 PM
    Hi Alagoutte,
    This is excellent work!  It would be fantastic if you would share this in our Aruba Programmability and Automation group.
    Could you please repost this information in our Airheads Developer Community, located here: https://community.arubanetworks.com/t5/Developer-Community/gp-p/NetworkAbstraction
    Thanks!
  • 3.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Dec 03, 2018 03:02 PM
    a new release available ! (0.6)
    What new :
    3 new cmdlets
    • Enhance speed (Don't wait 5sec between each request...) (#32)
    • Enhance security (Enable TLS 1.2 when HTTPS is used...) (#60)
    • Better "error" message when fail to connect or use a API (#55)
    • Add -usebasicparsing for use without connnected session (like task) (#56)
    • Add integration test (using Pester) for check code (Known issue about VSF Switch) (#36)
    • Add Get|Set-ArubaSWPort(-statistics) to get and configure a port (name, status, mode...) and Port statistics (name, packets/bytes/throughtput/error TX or RX...) (#40)
    • Add Extract-Port-ArubaSW.ps1 tools script for generate a Excel file with the list of Port and configuration (vlan, status, lldp neighbor...) (#34)
    • 4 removed cmdlets (Get-ArubaSWSystemStatus[Cpu|Memory|Storage|Time] (#43)
    For update
    Update-Module PowerArubaSW
    See also https://github.com/PowerAruba/PowerArubaSW/releases/tag/v0.6
  • 4.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Dec 10, 2018 04:59 PM
    Hi Alexis, is it possible to use in on Powershell Core for Mac? I have pwsh in both my windows and mac machines and it works well on windows but I'm getting an "unable to connect" error on mac. I'm trying to connect to the same device on both.
  • 5.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Dec 11, 2018 01:33 AM
    Hi Daniel,
    What release do you have using ? (get-module -name PowerArubaSW)
    There is some "known issue" with PowerShell Core and the module...
    Actually it is not possible to connect to secure way (HTTPS) (https://github.com/PowerAruba/PowerArubaSW/issues/38)
    if you enable http on switch and use -httpOnly to Connect-ArubaSW, can you connect ?
    We can continue on https://github.com/PowerAruba/PowerArubaSW/issues
  • 6.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Dec 11, 2018 06:54 AM
    Hi Alexis, I'm running `0.6`
    PS /Users/danieltudares> Get-Module -name PowerArubaSW
    ModuleType Version    Name                                ExportedCommands
    Script     0.6        PowerArubaSW                        {Add-ArubaSWLACP, Add-ArubaSWVlans, Add-ArubaSWVlansPorts,...
    and also my switch is an 2930f running the latest version
    l3-core(config)# show flash | include Image
    Image             Size (bytes) Date     Version
    Primary Image    :    29616419 11/21/18 WC.16.08.0001
    Secondary Image  :    29616419 11/21/18 WC.16.08.0001
    Default Boot Image   : Primary
    and yes, I tried with the httpOnly flag and it worked, seems to be only over https.
    I'll be following the ticket for the resolution, thanks a lot!
  • 7.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Dec 11, 2018 08:38 AM
    Thanks Daniel for feedback,
    the support of Powershell Core is planned for next release but i don't when ;-)
    I have already look but it will be easy to fix for Core (need to add -SkipCertificate to Invoke-WebRequest)
  • 8.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Feb 22, 2019 04:07 AM
    Hi Daniel,
    You can now use with your macOS !
  • 9.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Feb 22, 2019 04:06 AM
    a new release of PowerArubaSW is available (0.7)
    What New ?
    4 new cmdlets
    • Add support of PowerShell 6(/Core)
    • Now run (and validated) under Linux and macOS
    • Add fix some issue with Stacked/VSF switch
    • Adding DNS support (Get/Set/Remove DNS server and domain names)
    more info https://github.com/PowerAruba/PowerArubaSW/releases/tag/v0.7
    Like always for update
  • 10.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Apr 03, 2019 12:08 PM
    I apologize if this should be a separate thread vs a question on your PS module:
    I'm trying to determine if the REST API for ArubaOS allows toggling the PoE state on a given port?  Aka: Port E6: turn off PoE.
    If it's possible, can someone give a syntax example for the request?
  • 11.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Apr 03, 2019 12:14 PM
    Hi tbig,
    There is already a "issue" on GitHub about PoE function
    https://github.com/PowerAruba/PowerArubaSW/issues/71
    There is already the command for get PoE Status...
    and it will no be complicated to change status (need to look API docs)
    I think include PoE for 0.8 or 0.9...
  • 12.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Apr 03, 2019 12:33 PM
    Just to confirm, does the REST API support a change to the PoE state?
    Documentation I saw referenced a post command to the PoE end point, but it
    wasn't clear how it works, if at all.
    I'd be grateful to see a curl command or anything if it's currently possible
  • 13.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Apr 03, 2019 01:26 PM
    from the doc, yes it is possible
    You need to use uri : .../poe/ports/{PortPoe.port_id}/reset with HTTP method "POST"
  • 14.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Apr 03, 2019 02:18 PM
    Hmm... the only version of the API where I see that endpoint referenced in is from "Aruba REST API Guide for ArubaOSSwitch 16.05"
    https://support.hpe.com/hpsc/doc/public/display?docId=a00040422en_us
    Also, when you get to the end of the section it says:
    Note: Applicable only for ArubaOS-Switch 5400R.
    Are you looking at any other version of the OS or a different API doc?
    (Sorry this is my last question!) :D
  • 15.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Apr 03, 2019 02:54 PM
    There is some typo on this doc...
    You need to look : 16.08 REST API and JSON Schema (for example : https://h10145.www1.hpe.com/downloads/DownloadSoftware.aspx?SoftwareReleaseUId=24618&ProductNumber=JL557A&lang=&cc=&prodSeriesId=&SaidNumber= )
  • 16.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Apr 03, 2019 04:28 PM
    Just to close the loop - thanks, the link you provided was a huge help.
    We're on 16.03, and I don't see that reset method available (and I get a 404 error when trying it).  I do see it in the 16.08 schema, and we're likely to be upgrading soon to that, at which point I can test further.
    At any rate, thanks for clearing some of the fog. :D
  • 17.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Apr 04, 2019 05:32 AM
    I need to check because i get same strange issue when try PoE reset API...
  • 18.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted May 11, 2019 02:02 AM
    a new release is available (0.8.0)
    What new ?
    14 new cmdlets !
    For Trunk, STP, PoE, IP Address (Get only)...
    There is also the support of AnyCli and cliBatch
    For example
    Get-ArubaSWCli -cmd "show running"
    and one of major feature of this release it is the support of multi-connection. it is possible to connect to multiple switch on same time using -connection parameter
    for example
    $sw1 = Connect-ArubaSW 192.168.0.1
    $sw2 = Connect-ArubaSW 192.168.0.2
    After for get vlans
    Get-ArubaSWVlans -connection $sw1
    Get-ArubaSWVlans -connection $sw2
    More info => https://github.com/PowerAruba/PowerArubaSW/releases/tag/v0.8.0
  • 19.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Aug 12, 2021 02:18 PM
    Hi alagoutte,
    thx for your work!
    I´m searching for a soltution, how I could disable all ports which have a vlan id untagged assigned, but I can´t figure out how to implement this...
    Any ideas? What I have is:
    $IP = 10.20.252.10
    Connect-ArubaSW $IP
    $ports = Get-ArubaSWVlansPorts -vlan_id 300
    foreach ($port in $ports) {
    if ($port.port_mode -eq "POM_UNTAGGED") {
    Send-ArubaSWCliBatch -command "port $port.port_id", "disable"
    #Set-ArubaSWPort -port_id $port.port_id -is_port_enabled
    Matthias Pohl
  • 20.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Aug 18, 2021 03:22 PM
    Hi Matthias,
    look good... what don't work ?
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 21.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Aug 12, 2021 02:50 PM
    I tried to change the VLAN on one port, but I get:
    PS C:\Users\mph> Set-ArubaSWVlansPorts -port_id 3 -port_mode Untagged -vlan_id 350
    WARNUNG: The Switch API sends an error message:
    WARNUNG: Error description (code): Not Found (404)
    WARNUNG: Error details: {
    "message": "Error 404: Not Found."
    Unable to use switch API
    In C:\Program Files\WindowsPowerShell\Modules\PowerArubaSW\0.8.0\Private\Webrequest.ps1:84 Zeichen:13
    + throw "Unable to use switch API"
    + CategoryInfo : OperationStopped: (Unable to use switch API:String) [], RuntimeException
    + FullyQualifiedErrorId : Unable to use switch API
    PS C:\Users\mph>
    Any ideas?
    Matthias Pohl
  • 22.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Aug 18, 2021 03:23 PM
    Strange,
    What the switch model and version ?
    can you post on issue of Github ? https://github.com/PowerAruba/PowerArubaSW/issues
  • 23.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Jan 14, 2022 06:49 AM
    For info, new release is available : PowerArubaSW 1.0.0 with :
    What's Changed
    and also from older release
    • Add PowerArubaSW Logo (#123)
    • Adding RADIUS Server (#107)
    • Adding RADIUS ServerGroup (#108)
    • Adding RADIUS Profile (#122)
    • Adding MAC (Table) (#110)
    • Adding Ping (#114)
    • Adding Display Modules Information (#112)
    • Adding Banner (motd/exec) (#111)
    • Adding Github Actions (for PSSA and Deploy release) (#113)
  • 24.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted May 02, 2022 10:08 AM
      Is possible to run a command like this   "copy startup-config tftp://xxx.xx.x.xxx/backup_test cli vrf default" ?
    I try to make  an automatically back-up copy at configuration.
    In the command list I see only get, remove, set.
    Thank you , Have a great day.
    Adrian Ca
  • 25.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted May 02, 2022 03:25 PM
    This CLI command is for Aruba CX
    you can get the configuration but using json format
  • 26.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Jan 03, 2024 04:05 AM
    just what I was looking for - thank you
    Setting this up for non-technical staff is working great however when I updated the switch from YA.16.09.0015 to YA.16.10.0009 I get failed to connect message below
    Unable to connect
    At C:\Program Files\WindowsPowerShell\Modules\PowerArubaSW\1.0.0\Public\Connection.ps1:157 char:13
    +             throw "Unable to connect"
        + CategoryInfo          : OperationStopped: (Unable to connect:String) [], RuntimeException
        + FullyQualifiedErrorId : Unable to connect
    I'm using -SkipCertificateCheck which works fine on YA.16.09.  not been able to get this working without skipping
  • 27.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Jan 03, 2024 05:14 AM
    What powershell release?
    What do you are using for connection ? admin/manager account ? or RBAC (RADIUS/TACACS ?)
  • 28.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Jan 03, 2024 06:13 AM
    v5 (on win10)
    local manager account
  • 29.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Jan 03, 2024 08:35 AM
    Strange,
    can you enable debug rest on switch ?
    try also with -verbose ?
    do you have also check the certificat (show web-management)
  • 30.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Jan 03, 2024 09:09 AM
        amp-server: AMP server configuration is disabled due to first configuration.
        crypto: Certificate used by http-ssl application is not yet valid.
        VERBOSE: POST https://xxx.xxx.xxx.xxx/rest/v3/login-sessions with -1-byte payload
    I understand the cert part isn't working but on the old version I could connect with -skipcerticatecheck
  • 31.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Jan 03, 2024 09:25 AM
    the HTTP is enable ? (only for try), you can test with -httpOnly
    can you regenerate certificate on the switch ?
  • 32.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Jan 03, 2024 09:38 AM
    I had already tried -httponly - just tried again and same issue.  I also disabled SSL and same error (SSL is re-enabled as below)
     Web Management - Server Configuration
      HTTP Access    : Enabled
      HTTPS Access   : Enabled
      SSL Port       : 443
      Idle Timeout   : 600 seconds
      Management URL : http://h17007.www1.hpe.com/device_help
      Support URL    : http://www.arubanetworks.com/products/networking/
      User Interface : Improved
    I did do this before posting, I even defaulted the switch and set back up
    if I switch to secondary ROM with old version of firmware I can connect.
    using the new firmware on primary ROM I get these errors above
  • 33.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Jan 03, 2024 11:53 AM
    what log do you have httponly?
    i try with firmware YA.16.11.0007 and work for me (with PS 5 and PS7) can you try 16.11 ?
  • 34.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Jan 04, 2024 05:46 AM
    Edited by Ezio Jan 04, 2024 05:47 AM
    yep YA.16.11 worked - didn't expect HP to release a bug :)   (YA.16.10 was the latest firmware I had)
    thank you for your assistance and thanks again for the module - good work
  • 35.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Jan 05, 2024 03:59 AM
    i remember an issue with some 16.10 release but i think it is fixed on last 16.10 !
  • 36.  RE: PowerArubaSW : a powershell module for use ArubaOS Switch REST API
    Posted Jan 05, 2024 04:01 AM
    after a quick check of release note :
    16.10.0011 253965 YA/YB Symptom: The switch closes the REST connection
    when the request is made from a Windows client.
    Scenario: This issue occurred when a REST
    request was sent from PowerShell on a Windows
    client.
