Cloud Managed Networks
Pre-Provisioning Switches and APs to Sites
This thread has been viewed 24 times
  • 1.  Pre-Provisioning Switches and APs to Sites
    Posted Apr 07, 2025 03:30 AM
    Dear Experts,
    I think we can pre-provision switches and APs to groups but can we assign them to their respective sites before they are turned on and connected to central?
    iqbal
  • 2.  RE: Pre-Provisioning Switches and APs to Sites
    Posted Apr 07, 2025 04:25 AM
    No that is not possible. You can pre-assign devices to groups but not to a site. An alternative is using the Aruba installer app. This app will assign the devices to a group and site.
    Willem Bargeman
    Systems Engineer Aruba
    ACEX #125
  • 3.  RE: Pre-Provisioning Switches and APs to Sites
    Posted Apr 07, 2025 04:32 AM
    But that will require separate usb dongle to be purchased right?
  • 4.  RE: Pre-Provisioning Switches and APs to Sites
    Posted Apr 07, 2025 04:38 AM
    No, I mean the Aruba Central install manager app. Hereby a link to the documentation
    Willem Bargeman
    ACEX #125
  • 5.  RE: Pre-Provisioning Switches and APs to Sites
    Posted Apr 07, 2025 04:40 AM
    Also can you share the process (or link) on how to pre-provision the device based on its serial/mac to central group before its connected to aruba central?
  • 6.  RE: Pre-Provisioning Switches and APs to Sites
    Posted Apr 07, 2025 04:44 AM
    Sure! documentation link
    Willem Bargeman
    ACEX #125
  • 7.  RE: Pre-Provisioning Switches and APs to Sites
    Posted Apr 07, 2025 04:48 AM
    i already gone through it, it requires devices to be connected to aruba central first. I want to pre-provision before they are connected
  • 8.  RE: Pre-Provisioning Switches and APs to Sites
    Posted Apr 07, 2025 04:55 AM
    No, this will work before a device is connected. Just make sure that the device is assigned to Central in GreenLake. If that is done the devices should be visible in the pre-provisioning tab.
    Willem Bargeman
    ACEX #125
  • 9.  RE: Pre-Provisioning Switches and APs to Sites
    Posted Apr 07, 2025 05:04 AM
    Yes understood, but can we pre-provision in bulk?
  • 10.  RE: Pre-Provisioning Switches and APs to Sites
    Posted Apr 07, 2025 04:52 AM
    ok sorry i can pre-provision the devices however its done one by one. Cant we do it bulk like 40 switches with serial numbers assigned to x group based on their serial/mac?
  • 11.  RE: Pre-Provisioning Switches and APs to Sites
    Posted Apr 07, 2025 05:28 AM
    Yes, you can filter in the Device Preprovisioning view and then select multiple devices
    Willem Bargeman
    ACEX #125
  • 12.  RE: Pre-Provisioning Switches and APs to Sites
    Posted Apr 07, 2025 11:23 AM
    Thanks for the info I found this useful myself.  Even if the OP may not have.
  • 13.  RE: Pre-Provisioning Switches and APs to Sites
    Posted Apr 08, 2025 01:21 AM
    @Owais101  The simplest way is to use the group move API and send the device details in JSON format. You can move any number of devices in a single request.
    If you need I can share the  API and json format to post the request .
