Have you tried to use the 'upload and use saved key'? It actually may work.
Before you do that, export your current certificate from the Certificate Store, and have it password protected so you get the private key with it. You will get a .p12 if I'm correct.
In case upload with the saved key does not work, you can extract the current private key from the export. OpenSSL will do that, but other methods will work... I just would not use any cloud/internet service for it as they will have access to your private key. Then either create a new .p12 with the existing key and new cert, or create PEM for both the key and the cert and upload those.
Original Message:
Sent: Jul 22, 2021 04:48 PM
Subject: Private key for importing https certificate
Hi All.
We are using GoDaddy certificate for https in our clearpass environment. The certificate is getting expired soon and it was auto-renewed by GoDaddy without us sharing the CSR. But we received only the certificate file and not the private key. Please let me know how to get the private key. Also please suggest whether we can use 'Upload Certificate and Use Saved Private Key:' option for import in this scenario.
Thanks.
Alin Baby
