I have a problem with the NPS authenticator on a H3C switch 5130, as soon as the authentication is done on the switch, the connection window closes automatically, here is the configuration of the NPS server and the switch.
version 7.1.045, Release 3113P03
sysname HPE
telnet server enable
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 3 priority 1
lldp global enable
password-recovery enable
vlan 1
stp global enable
interface NULL0
interface Vlan-interface1
ip address 172.x.x.x255.255.255.0
line class aux
user-role network-admin
line class vty
user-role network-operator
set authentication password hash $h$6$JTqsScarIvCKmRsn$iWKS1gPpqe9QUQ0h7/8V4EeF8ZQsoCXAadHf7nCWbs7TKgHMTQyPcGqweNAe8tsoBR+W9EG2duU8GWPomIz2EQ==
line aux 2
line vty 0 4
protocol inbound telnet
line vty 5 63
authentication-mode scheme
protocol inbound ssh
ip route-static 0.0.0.0 0 172.x.x.x
ssh server enable
radius scheme radius1
primary authentication 172.x.x.x
primary accounting 172.x.x.x
key authentication cipher $c$3$h4cvGSxM90SB9ROCvK3Q0NvtKTaVnCgq1TCW
key accounting cipher $c$3$FJERGg3cUgJg+COvFwKZ1FTTcW7AU4+YZZ4E
user-name-format without-domain
radius scheme system
domain system
authentication login radius-scheme radius1 local
authorization login none
accounting login radius-scheme radius1 local
domain default enable system
user-group system
local-user admin class manage
password hash $h$6$ZZMqo7xH2weDC3rk$PPk2wMJFhMqxOf3k1jIeaQP3vfGTjWvQUOnxCuhRI8MNkPAIAyjbD1WMBvM8tAHVeGKZUUhHfzpZJAJVDE8wAQ==
service-type ssh telnet
authorization-attribute user-role network-admin
authorization-attribute user-role network-operator
local-user read class manage
The prints of screens are attached.
Would you have a solution to offer me please?
Thank you
Mathieu
