Problem create an SSD that is isolated from my internal network
  • 1.  Problem create an SSD that is isolated from my internal network
    Posted Aug 30, 2024 04:40 AM
    How can I create an SSD that is isolated from my internal network and I do not have a license (WEBCC) ?
  • 2.  RE: Problem create an SSD that is isolated from my internal network
    Posted Sep 02, 2024 03:21 AM
    Hi Sani.
    As you posted this question in Controllerless Networks I presume that you are using Aruba Instant and not controller based APs. For Instant you don't need a license.
    Just use separate vlan for this ssid.
    If by any chance you are on the controller managed network, then WEBCC subscription has nothing to do with SSID separation. You would like to have PEF license but it is not mandatory. As in Instant, just select the different vlan for this SSID and also you can use different port on the controller for this traffic.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
