Problem getting RAP5-WN up - sapd_check_hbt doing tunnel down.
  • 1.  Problem getting RAP5-WN up - sapd_check_hbt doing tunnel down.
    Posted May 07, 2012 05:06 PM
    So I have a controller on 6.1.2.5 with several RAP-2s and RAP-5s already up and working happily.
    I got a new RAP5.  The firmware on both the boot and backup paritions is 5.0.4.5, so I should be able to get it to attach to my 6.x controller and upgrade it.
    But when I try to get it to attach, everything seems ok at first.  The web browser on the attached client gets successfully though
    Uplink Status
    IP Information
    Gateway Ping
    TPM Certificates
    When it hits Master Connectivity I get the message
    IP X.X.X.X using Ethernet Aborted : sapd_check_hbt id doing tunnel down
    It then proceeds to successfully pass "LMS Connectivity"
    and then spins forever on "Continuing"
    Any ideas how to start debugging this?  I would suspect a controller config error, but I have working good RAPs off the controller.
    Jeff
  • 2.  RE: Problem getting RAP5-WN up - sapd_check_hbt doing tunnel down.
    Posted May 07, 2012 05:42 PM
    Haven't seen that message before.  I'd probably start with factory resetting the RAP (pin the reset button) and starting over.
  • 3.  RE: Problem getting RAP5-WN up - sapd_check_hbt doing tunnel down.
    Posted May 08, 2012 10:51 AM
    I've already done a factory reset sever times to no avail.
  • 4.  RE: Problem getting RAP5-WN up - sapd_check_hbt doing tunnel down.
    Posted May 08, 2012 06:48 PM
    Is this RAP connected at the same location as other working RAPs?
    I hope it is added to the whitelist on the master controller.
    When AP is trying to come-up, do you see ISAKMP SA and IPSEC SA being formed? (chow crypto isakmp sa // show crypto ipsec sa)
    If so, check "show user-table verbose" and make sure RAP falls into the AP-Role.
  • 5.  RE: Problem getting RAP5-WN up - sapd_check_hbt doing tunnel down.
    Posted Feb 05, 2013 08:28 AM
    I am getting same error with a RAP-2.
    I've even taken the RAP-2 and defaulted and connected directly to my local LAN with the controller and I'm still getting same error. I also tried removing them from whitelist and try to let them come up as a normal AP but that isn't working either.
    IPSEC SA shows them trying to connect and show user-table verbose shows them in the AP-Role.
    Any suggestions?
  • 6.  RE: Problem getting RAP5-WN up - sapd_check_hbt doing tunnel down.
    Posted Feb 05, 2013 08:53 AM
    This is output with RAP connected directly to LAN with controller. RAP is on whitelist and is pointed towards the internal LAN address of the controller.
    (ADK-620) (config) #show crypto isakmp sa
    ISAKMP SA Active Session Information ------------------------------------ Initiator IP     Responder IP   Flags       Start Time      Private IP ------------     ------------   -----     ---------------   ---------- 10.0.0.133       10.0.0.11      r-m-c-y-R Feb  5 09:49:00   192.168.4.181
    Flags: i = Initiator; r = Responder        m = Main Mode; a = Agressive Mode v2 = IKEv2        p = Pre-shared key; c = Certificate/RSA Signature; e =  ECDSA Signature        x = XAuth Enabled; y = Mode-Config Enabled; E = EAP Enabled        3 = 3rd party AP; C = Campus AP; R = RAP        V = VIA; S = VIA over TCP
    Total ISAKMP SAs: 1
    (ADK-620) (config) #show user-table verbose | include 2f:7b 192.168.4.182  00:00:00:00:00:00  00:0b:86:c3:2f:7b               ap-role        00:00:02    VPN            10.0.0.133  N/A        tunnel                              Internal     1
    (ADK-620) (config) #show crypto ipsec sa
    IPSEC SA Active Session Information ----------------------------------- Initiator IP     Responder IP     InitiatorID         ResponderID         Flags    Start Time      Inner IP ------------     ------------     -----------         -----------         -----  ---------------   -------- 10.0.0.133       10.0.0.11        192.168.4.182/32    0.0.0.0/0           T      Feb  5 09:53:11   192.168.4.182
    Flags: T = Tunnel Mode; E = Transport Mode; U = UDP Encap        L = L2TP Tunnel; N = Nortel Client; C = Client; 2 = IKEv2
    Total IPSEC SAs: 1
    When I connect pc to RAP-2 E1 is shows the following on the browser.
    Successful eth0 interface up
    Successful IP 10.0.0.133 mask 255.255.255.255.0 Gateway 10.0.0.7
    Gateway Ping successfull
    TPM Certificates successfull
    Master Connectivity  IP 10.0.0.11 ((Controller LAN address)) using Eternet Aborthed sapd_check_hbt is doing funnel down
    LMS Connectivity Successful LMS IP 10.0.0.11 using Ethernet
  • 7.  RE: Problem getting RAP5-WN up - sapd_check_hbt doing tunnel down.
    Posted Mar 05, 2014 03:52 PM
    I am also experincing same issue. Could you let me know what is the current code version on the controller and RAP's backup partition?
  • 8.  RE: Problem getting RAP5-WN up - sapd_check_hbt doing tunnel down.
    Posted Mar 26, 2014 04:54 PM
    We're seeing this error with controller ArubaOS 6.3.1.3 and RAP OS 5.0.4.0.
  • 9.  RE: Problem getting RAP5-WN up - sapd_check_hbt doing tunnel down.
    Posted Apr 01, 2014 05:11 AM
    i have excatly the same pb with controller ArubaOS 6.3.1.3 and RAP5-WN OS 5.0.4.0....
  • 10.  RE: Problem getting RAP5-WN up - sapd_check_hbt doing tunnel down.
    Posted Apr 01, 2014 08:26 AM
    We opened a TAC case about this and we were informed of two things.  One, this is a bug in code 6.3.1.3.  It's supposedly resolved in 6.3.1.4.  I guess we're going to have to test the waters with that.  We also found out that the RAP2s and RAP5s were EOL in October and will not be supported beyond 6.3.x.  So if you are planning on upgrading to Aruba OS 6.4 at any point keep in mind that you will have to replace all of your RAP2s and RAP5s.  This bit us because we bought a few of the new outdoor AP-270 series and they only come as IAPs.  If you want them to be a part of your controller network (which, of course you would, why on earth would you want to manage an IAP network and a contoller network in one a single campus.... but I digress) they require the controllers to be on ArubaOS 6.4.x which is in ED.
  • 11.  RE: Problem getting RAP5-WN up - sapd_check_hbt doing tunnel down.
    Posted Apr 01, 2014 08:44 AM
    thanks for your answer.
    I try with 6.3.1.4 in couples of hours..
    Aurélien.
  • 12.  RE: Problem getting RAP5-WN up - sapd_check_hbt doing tunnel down.
    Posted Apr 01, 2014 04:45 PM
    Did v6.3.1.4 work?  Did you ahve the same issue with RAP-3's?
  • 13.  RE: Problem getting RAP5-WN up - sapd_check_hbt doing tunnel down.
    Posted Apr 01, 2014 04:47 PM
    We did "upgrade" the controllers to 6.3.1.4 and that fixed it the sapd_check error.   We didn't have any issues with RAP-3s on 6.4.  The legacy RAPs/CAPs aren't supported in 6.4.
  • 14.  RE: Problem getting RAP5-WN up - sapd_check_hbt doing tunnel down.
    Posted Apr 01, 2014 04:50 PM
    Thank you.  I was wondering if you had any issues with the RAP-3s while you were on v6.3.1.3 similar to what you saw with the RAP-2s.
  • 15.  RE: Problem getting RAP5-WN up - sapd_check_hbt doing tunnel down.
    Posted Apr 01, 2014 04:55 PM
    To be honest, I don't know if the RAP-3s were experiencing the issue.  We upgraded our masters to 6.4.0.2 and couldn't get our RAP-2s to work.  I had a RAP-3 on hand that came online without issue on 6.4.  When we rolled our controllers back to 6.3.1.3 this morning, the teleworker with the RAP-3 was actually on site so her RAP wasn't online.  We upgraded the controllers to 6.3.1.4 and all of our RAP-2s came online after the clients did a reset.
  • 16.  RE: Problem getting RAP5-WN up - sapd_check_hbt doing tunnel down.
    Posted Apr 02, 2014 12:05 PM
    I confirm, it's work perfectly with 6.3.1.4
    Thx,
    Aurélien.
  • 17.  RE: Problem getting RAP5-WN up - sapd_check_hbt doing tunnel down.
    Posted Nov 12, 2012 08:30 AM
    One of our customers has an office in China and when they try to connect a RAP to a MS in the UK they get the same error.
    This is because the Government is doing a reform and they have completely locked down the internet.
    Please see below link for the article.
    http://asia.cnet.com/expect-slow-internet-this-week-in-china-62219398.htm
